| achan1989 |
 achan1989 L Plate Warrior
| bikenut |
 bikenut World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:47 - 07 Mar 2012 Post subject: |
Have a good look at the arm on the clutch cover. Is it moving freely when you pull the lever?
Is it bent and fouling on the cover, or is its travel being limited? Is cable kinked or fouling on anything? ____________________ Biking is 1/20th as dangerous as horse riding.
| Teflon-Mike |
 Posted: 13:42 - 07 Mar 2012 Post subject: |
If you went down on the Right Hand side, then the primary drive cover can get 'holed'. Normally not the foot-peg, but by the brake pedal.
Often sits with the pedal head close to teh bottom of teh casing, and the inside is quite 'sharp'.. had to repair a couple of Super-Dream cases with holes in exactly the place where the pedal head would 'strike'.
So first of check for oil leaks.
Next up; the clutch actuation mechanism sits in the primary drive cover over the end of the clutch basket.
The cable from the handle-bar lever comes down from the hand-lever, goes to a bracket on the primary drive cover then tugs a lever on a shaft going through the primary drive cover.
https://i178.photobucket.com/albums/w269/teflons-torque/Little%20Dreams/LD07%20Eng%20Build/100_0496.jpg
That shaft sits on bosses cast inside the cover, and between them is a lever/rocker that bears on the clutch release rod.
IF the casing has taken a hefty smack; then a few imediate faults spring to mind:-
1/ The Casing has been damaged and the rocker has 'slipped' on the actuation shaft.
2/ The actuation rod has been dislodged from its seat on the rocker
3/ (& possibly the most likely) The actuation rod has 'bent'
4/ The casing is damaged and the actuation shaft is bent or the bosses it sits in are cracked.
THIS is presuming that the crash & the clutch fault are connected... MAY be entirely co-incident, and you had a worn out clutch before & oil-change has simply shown up the problem, or post crash adjustment.
EITHER WAY: the answer is to pull the primary drive cover off and have as shuftie.
SNOWIE (Keep getting told off when people thank me for her efforts!) Has written a Handy How to on overhauling the small-honda clutch:-
HOW2: Overhaul Clutch (Small Honda's +)
Walks you through the process of removing & replacing drive cover, and stripping the clutch mechanism, & if needs be replacing clutch plates and springs.
Clutch plates & Springs are about £15, and mention is made of a castle nut socket; which we made, first time around, but 'propper' honda tool is available from Riders of Yeoville, (Cheap source of plates & springs too) for about £12, to make the job easier.
So for £30 you could overhaul the basket while you were in there, which as little learner bikes tend to get a lot of clutch abuse, may be worth-while preventative maintenence / piece of mind, anyway.
But pay close attension to the actuation mechanism in the casing when you remove it, and the actuation rod that goes through the middle of the clutch.
Take it out, get a nice flat surface and roll it around make sure its not bent. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| achan1989 |
 Posted: 21:34 - 07 Mar 2012 Post subject: |
Quick follow-up: old oil was relatively clean, clutch cable and mechanism work smoothly, and the casing looks ok on the outside at least...
I'm gonna pop the case this weekend, new clutch plates and all that jazz. That's a great looking guide
Thanks for the advice everyone. |
The last post was made 13 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
