 darthbuttchin Scooby Slapper
 Posted: 16:08 - 07 Mar 2012 Post subject: CG125 Issues |
Hi all,
You may have seen the odd post from me elsewhere about my bike.
Basically, I bought it as a restoration project, so I had an idea of how to fix bikes. It's *nearly* there (motions tiny amount with fingers).
However, there is a dreaded electrical (i think) issue.
Basically, we changed the ignition (as the key for the old one was missing) and it doesn't seem to do anything. The bike starts since we changed the points, but you only have to kick-start it, no need for the ignition to be on. Consequently, the ignition won't turn it off either, so you have to stall the bike to stop it, which is a pain (although it get's your rodeo skills up to scratch round the garden!).
The bike also appears to be blowing the fuse - although the bulbs appear to still be fine and all. Could it be the issue with the ignition which is causing the fuse to blow?
I should point out that I fucked up when looking at the earth on the main frame. I unscrewed it to clean it and check it was alright. After that, I was bolting it back on and either I had a Hulk moment of super strength (unlikely) or the bolt was made of silver cheese (more likely) and the head snapped off. We moved the main earth to the other side of the bike - would this cause a problem do you reckon?
The bike is a CG125-K1 (1978), and on 6V electrical system. I have changed ignition coil as well, and all the wires seem fine (no black strands etc - i think the loom was replaced not so long ago).
Tl;dr - changed ignition, doesn't affect bikes on and off - need to stall to stop. Also keeps blowing fuses - have moved position of main-frame earth due to personal fecklessness, could this be a problem?
Cheers,
db ____________________ CG125-K1 (1978) - 35 years old and (mostly) going strong! (Restored and rebuilt by my own fair hands).
Call me Tomsk - I am the Flying Womble after all. |
 truslack World Chat Champion
 von1papen Spanner Monkey
