| Usher4566 |
 Usher4566 Spanner Monkey
| _Iain_ |
 _Iain_ Banned
 Posted: 15:34 - 08 Mar 2012 Post subject: |
Two threads for the same problem will most likely wind people up.
You've been told how to check it for air leaks, unless you stripped the carb down and fucked about with mixture screws and shit then its not going to be settings related.
You put a carb slide in the wrong way round or something? ____________________ Please be aware that the above post may be full of complete nonsense.
| Usher4566 |
| _Iain_ |
 _Iain_ Banned
 Posted: 16:58 - 08 Mar 2012 Post subject: |
https://www.startright.co.uk/images/mini-20010101_0004.JPG
If the carb looks like this, have a look down the end. Is it about 1-2mm open, or half way?
If its the latter, unscrew the top (where the throttle cable goes in) turn the slide round 180 degrees & put it back in. see if the opening is then much smaller...did it on a C90 and it made my head hurt for quite a while. ____________________ Please be aware that the above post may be full of complete nonsense.
| Usher4566 |
| _Iain_ |
 _Iain_ Banned
 Posted: 17:32 - 08 Mar 2012 Post subject: |
https://www.dansmc.com/carb_needle.jpg
Looks like that.
however on the side you see that slit? that sits over the idle screw. if you put it in the wrong way round then the slide cant close more than half way because the base of the slide hits it. ____________________ Please be aware that the above post may be full of complete nonsense.
| Usher4566 |
| Usher4566 |
| Usher4566 |
| _Iain_ |
 _Iain_ Banned
 Posted: 17:42 - 08 Mar 2012 Post subject: |
Phone, video, youtube it, and add a link.
What the fuck is a shuttle?!
my guess is you pulled all the screws nuts and bolts out that you could get your hands on without taking note of what the mixture screws were set at, and then re assembled it with a load of air leaks & incorrect clearances. ____________________ Please be aware that the above post may be full of complete nonsense.
| _Iain_ |
 _Iain_ Banned
 Posted: 17:45 - 08 Mar 2012 Post subject: |
Sudden thought, but what happens if you turn the idle screws down a load?
If the clip was set in one position, why the hell do you want to change it!? that then just adds another potential problem into it all  ____________________ Please be aware that the above post may be full of complete nonsense.
| Usher4566 |
| _Iain_ |
 _Iain_ Banned
 Posted: 18:00 - 08 Mar 2012 Post subject: |
In which case, am i being proper simple here, or is there a reason you cant adjust the idle speed down with the idle speed adjustment screw? ____________________ Please be aware that the above post may be full of complete nonsense.
| Usher4566 |
| _Iain_ |
 _Iain_ Banned
 Posted: 18:10 - 08 Mar 2012 Post subject: |
https://i2.kym-cdn.com/entries/icons/original/000/000/554/facepalm.jpg
Float height adjusted wrongly, shit blown into the jets, original problem which made you rip the carb to bits, sticky slide, sticky cable, choke jammed on or incorrectly adjusted, air leak, consistant fucking around with anything and everything, incorrect mixture settings.
Any, or all of the above are your problem. I've heard so many people advising others to "clean the carb" when the bike runs rough without even having a look at weather the plugs f*cked. Ask questions, learn shit, watch others, THEN fuck about with stuff. ____________________ Please be aware that the above post may be full of complete nonsense.
| Usher4566 |
The last post was made 13 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
