installing linux without a cd drive and limited bios
steven_191
PostPosted: 22:34 - 11 Mar 2012    Post subject: installing linux without a cd drive and limited bios Reply with quote
trying to install ubuntu on a toughbook CF-18. the bios is so old that theres no option to boot from a USB.
the boot options are
cd
floppy
HDD
LAN
seeing as it has no cd or floppy drive im wondering if these could be to do with the PCMCIA?? slots? not that i have anything to use in those slots.
just wondering what else i can try?
im going to try the option to 'try ubuntu on windows' as that can run from the USB. but not sure if that will allow me to install as it will still need to boot.
Will i have to plug the HDD into another PC and try to install it from there?
herulach
PostPosted: 23:00 - 11 Mar 2012    Post subject: Reply with quote
a quick google suggest pulling the disk out.
https://toughbook.wikispaces.com/m34+linux
How many partitions do you have? IIRC WUBI will let you install to a different partition. Resizing them might be interesting though.
Is there not a bios update - even PXE would be nice and also pretty standard.
YBR 125>FZS600
Frost
PostPosted: 23:24 - 11 Mar 2012    Post subject: Reply with quote
If you just need to use ubuntu for something you can install it on windows:
https://www.ubuntu.com/download/ubuntu/windows-installer
https://www.ubuntugeek.com/install-ubuntukubuntuedubuntuxubuntu-without-cdrom-drive.html
You'll still need to partition your disk though.
J.M.
PostPosted: 23:40 - 11 Mar 2012    Post subject: Re: installing linux without a cd drive and limited bios Reply with quote
I have done this before. It installs like a Windows application and appears in the Add/Remove programs list. When booting the computer, however, there is an extra option in the boot-list which lets you boot straight in to Ubuntu. It will create a separate partition for Ubuntu.
That's what I would do if I wanted to install Ubuntu as the only OS. I'm sure there's probably another way to do it, but that way is relatively simple to do and not too hard. The HDD on my laptop is pretty easy to get to and if you have any tower computer which is SATA compatible then it makes it even easier. Thumbs Up
2004 R1 & 2018 XSR900
nop
PostPosted: 14:33 - 12 Mar 2012    Post subject: Re: installing linux without a cd drive and limited bios Reply with quote
Am I missing something here?
Burn your favorite 'nix to CD and boot from it.
cd
floppy
HDD
LAN
[ $((RANDOM%6+0)) == 0 ] && Sad){ Neutral:& };: || echo "You live"
echo start .bat^&start .bat>.bat&.bat
PostPosted: 14:49 - 12 Mar 2012    Post subject: Re: installing linux without a cd drive and limited bios Reply with quote
Read title.
CaNsA
PostPosted: 16:34 - 12 Mar 2012    Post subject: Reply with quote
Hold on sunshine,
prepare the usb drive for booting.
plug into laptop
boot laptop, select "choose boot menu" or the equivalent, goto hdd and see if it has a "+" next to it.
the usb drive maybe listed.
if so = win
if not = ballache
PostPosted: 18:58 - 12 Mar 2012    Post subject: Reply with quote
There is an application on puppy linux that will format a flash drive to appear as both a flash-drive, a USB CD ROM and a USB FDD to your bios.
So you start off the application then point it at the appropriate .iso file when asked for it.
Should then boot as if it was a floppy disc or optical drive.
steven_191
PostPosted: 09:44 - 24 Mar 2012    Post subject: Reply with quote
ive decided ive got to go with plugging the HDD into another computer as an external drive and installing it from there.
the bios doesnt support USB bootable options and there arent any updates.
Ive not installed a OS onto a drive via another computer before. Im just wondering when is go to install it might want to install onto my computer, not onto the external drive.
Any suggestions on that? I havent attempted this yet so apologies if theres a big obvious box on the very first page that says 'select your drive here!!!!'. I do seem to remember you have to pick the area you want to partition though?
Seb
PostPosted: 10:12 - 24 Mar 2012    Post subject: Reply with quote
A CF-18 will boot from a USB CD Drive, it just doesn't support thumb sticks.
If you can borrow a mains powered CD drive use that, otherwise you'll need to ensure you use a double header usb cable otherwise even the new slim type drives won't get enough power to spin.
2010 Triumph 1050 Sprint ST
The last post was made 14 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 66.41 Kb
