| Dru2000d |
 Dru2000d Nova Slayer
 Posted: 20:48 - 26 Sep 2004 Post subject: Exhaust leaking oil??? |
this bike is doing my head in!! i now have oil leaking from the end of my exhaust...what does this mean? (don't say i'm buggered)
also, i want to change the oil and filter but i cant find it. anyone know where it is? a diagram would be cool
its a 94 RG125 FUN
thanks guys  |
| stevo123 |
 stevo123 Nitrous Nuisance
 Posted: 21:21 - 26 Sep 2004 Post subject: |
If you are confident then try adjusting the oil mixture pump as sounds like its adjusted to strong. Also check out the airfilter and give it a clean(make sure you oil the thing before putting it back in the airbox). Try also a new plug-always helps as well no matter what the problem is he he  |
| Dru2000d |
| mr jamez |
 mr jamez World Chat Champion
| Hex |
 Hex Party Boy
 Posted: 21:48 - 26 Sep 2004 Post subject: |
Personally I wouldn't adjust the oil mix, get it wrong and you'll seize the engine.
The oil coming out the exhaust is just unburnt oil. If it bothers you that much take the exhaust off and clean it out.
The oil filter.... If this is just a two stroke engine the oil is only for the gear box and as such won't have a oil filter. simply drain the oil and replace. Don't get the two stroke oil and gear box oil mixed up though. You'll want gear box oil 10-40 stuff Will probably be what you require.
Don't for get to keep the two stroke oil topped up as well, again not confusing the gear box oil and two stroke oil. ____________________ The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio |
| Dru2000d |
| mr jamez |
| Dru2000d |
 Posted: 22:24 - 26 Sep 2004 Post subject: |
ok thanks for that mate.
as you can tell i am a complete moron when it comes to bike maintenance!! although when i bought the thing it was wrecked at the front, fixed the lot up without a manual or experience. then the other day at work it wouldn't bloody start, GUESSED that the spark plug and air filter needed changing.
not bad for a novice
thanks for all your help!!! |
| Hex |
 Hex Party Boy
| Dru2000d |
| mr jamez |
 Posted: 22:35 - 26 Sep 2004 Post subject: |
No, don't fill it to the top and er brake fluid in there is not good either
You need to find out what amount of oil goes in there, and what type. It will probably be 10/40, if it says 1025ml then it is probably that. You can buy a small bottle of motorcycle gearbox oil for around £3.
There will be a drainer bolt to get the old oil out, usualy under the gear lever, warm the bike up for a few minutes and switch the engine off, then undo the bolt and drain all the oil out. Tighten it back up then refill with the correct amount, the filler cap should be on the side of the crankcase somewhere  |
| Dru2000d |
| mr jamez |
| Dru2000d |
 Posted: 22:57 - 26 Sep 2004 Post subject: |
oh yeah sorry
my girlfriend always says i never listen
thank you...again!!!
p.s. i'll let you know how it goes |
| Odie |
 Odie World Chat Champion
| Dru2000d |
The last post was made 22 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
