R reg Kawasaki ER-5 for £400, worth it?
Ribenapigeon
PostPosted: 16:00 - 19 Mar 2012    Post subject: R reg Kawasaki ER-5 for £400, worth it? Reply with quote
I have been offered a Kawasaki ER 5 for £400. It needs new tires and has no current MOT or tax. It has been stored under cover for a couple of years after the owner did there DAS but then dropped out of biking. (the story is true as far as i know as its a friends daughter so legit background to sale). Is it a good buy for when I pass (hopefully) my DAS later this summer?[/url]
FBSF
PostPosted: 16:19 - 19 Mar 2012    Post subject: Reply with quote
If you can hear / see it running, and know what to look for regarding what would be required to pass the MOT, then yes.
Otherwise, it could turn out to be more expensive than buying a taxed/tested one.
Even if it "flies through", you'll still need a set of tyres (£120ish), Tax (£50ish) and an MOT (£30ish) so straight away you are looking at £200 extra.
And that's before it has a full service (Oil, filter, air filter, plugs, brake fluid) which even if you do it yourself is going to cost £50-70. If you have to take it to a dealer, you are looking at £150-200 for that.
And if it's been sitting for 2 years, it's going to need it.
Which is then an £650-800 bike.
If you are confident in doing any work on it yourself, it could well be a bargain depending on its mileage. If not, I'd leave it be.
Frost
PostPosted: 16:30 - 19 Mar 2012    Post subject: Reply with quote
After being stood for a couple of years it will need:
New battery
Tank & carbs draining and probably cleaning
Fresh fuel
Oil change (condensation can get in)
I'd also expect rust to have got in places and would want to check bearings and stuff.
Amreet
PostPosted: 17:02 - 19 Mar 2012    Post subject: Reply with quote
Consumables are expensive and most of us have learnt the hard way that a 'cheap' bike usually works out to be the most expensive one. Tyres, filters, fluids, pads, cables, battery, it all adds up into a lot of money very quickly and the likelihood is you could probably find a far better example around the £700 mark that has been looked after, used and kept maintained.
Up to you which way you do it really, in some ways I kind of prefer doing the consumables my self, for exmaple I went and looked at some bikes that were advertiseds as 'new tyres, fluids etc. freshly serviced yadda yadda' that had been put back on the road for the bare minimum and probably done badly, horrendous chinese tyres, bike was a mess really so in that case I'd rather budget slightly higher to do the work myself and do it well, then you can have confidence in whats gone on/in the bike and it can also give you a good idea of condition.
Shinigami
PostPosted: 17:04 - 19 Mar 2012    Post subject: Reply with quote
check the brakes too. if it's been stood that long they may have seized?
Ribenapigeon
PostPosted: 17:53 - 19 Mar 2012    Post subject: Reply with quote
Thanks good advice and much as I thought. The bike has 17000 miles on it. It might be a nice project bike as one of the reasons I want a bike is for a bit of tinkering. Im not going to be tinkering with my brand spanking new Yamaha125, so having my 125 for a reliable commuter and somehting like an ER-5 would be good. The only thing im not sure I want to tinker with is brakes, theyre too imprtant and probably best left to a pro, further, bleeding brakes on a car is a pain and im supposing its no different on a bike.
Thanks for the possible costs involved im new to biking so dont have much of an idea.
PostPosted: 18:10 - 19 Mar 2012    Post subject: Reply with quote
Spares-or-repair = £300 tops. If the seller wants more, let them put the time and money in.
Suntan Sid
PostPosted: 19:57 - 19 Mar 2012    Post subject: Reply with quote
If you do get the chance to try and start it and it doesn't fire, try pulling the clutch lever in.
My neighbors' ER5 had been left for a couple of months, over winter, and wouldn't fire, pulling the clutch in, it fired straight away, presumably there was damp in the switch.
Chris750
PostPosted: 20:08 - 19 Mar 2012    Post subject: Reply with quote
Confused
My bike will not start without the clutch being pulled in, I thought that would be the case for most bikes??
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
Bomberman
PostPosted: 20:25 - 19 Mar 2012    Post subject: Reply with quote
Chris750 wrote:
Confused
Don't think so, surely that would just be annoying? I've not had/ridden one that needed clutch in to fire. Unless they've all had it disabled of course Very Happy
Chris750
PostPosted: 20:40 - 19 Mar 2012    Post subject: Reply with quote
Bomberman wrote:
Chris750 wrote:
Confused
It is annoying, I thought it was a "safety feature".
Bomberman
PostPosted: 18:08 - 21 Mar 2012    Post subject: Reply with quote
Well, live and learn. I just got delivered an 2011 SV650s as a courtesy bike while they write mine off and yup, won't start without the clutch in.
herulach
PostPosted: 18:26 - 21 Mar 2012    Post subject: Reply with quote
Your neutral or sidestand switch is bust.
YBR 125>FZS600
Cheeseybeaner
PostPosted: 18:35 - 21 Mar 2012    Post subject: Reply with quote
Don't see why it would necessarily need a new set of tyres. I have a bike which is mostly sat around and hasn't had its tyres changed in three years, no issues with them whatsoever.
Benson_JV
PostPosted: 18:55 - 21 Mar 2012    Post subject: Reply with quote
I believe it's all suzuki's that do this? Perhaps I'm wrong...
Bomberman
PostPosted: 19:03 - 21 Mar 2012    Post subject: Reply with quote
Hmmm, I don't think the GS's I did my training on did?
Bomberman
PostPosted: 19:07 - 21 Mar 2012    Post subject: Reply with quote
OP says it does.
herulach
PostPosted: 19:22 - 21 Mar 2012    Post subject: Reply with quote
Its not in gear right?
YBR 125>FZS600
Bomberman
PostPosted: 19:24 - 21 Mar 2012    Post subject: Reply with quote
Nope Very Happy Seriously the guy talked me through it when he dropped it off. No start without clutch in.
Cheeseybeaner
PostPosted: 19:25 - 21 Mar 2012    Post subject: Reply with quote
OP says it does.
Ok I see that now! I thought people were making the assumption that it needed new tyres due to being stood up 2 years. My mistake sorry.
PostPosted: 19:28 - 21 Mar 2012    Post subject: Reply with quote
£400 isn't a bad price for a basically sound bike but as above if it needs tyres and a chain & sprocket kit you'll have doubled your spending once you've got it MOt'd and the other bits done.
At least it should be cheap to run, last a long while and sell on easily.
_Troy_
PostPosted: 22:30 - 21 Mar 2012    Post subject: Reply with quote
Correct, it is indeed a Suzuki thing. Probably a half decent idea really, but a bit annoying to get used to at first.
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
The last post was made 14 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 119.07 Kb
