PLS Energy Saving Lamps
at106
PostPosted: 21:49 - 24 Mar 2012    Post subject: PLS Energy Saving Lamps Reply with quote
Does anyone know if these can run directly off mains electricity, or do they require extra components? These are the lamps https://www.maplin.co.uk/pls-energy-saving-lamps-98610
Thanks Karma
Codemonkey
PostPosted: 22:24 - 24 Mar 2012    Post subject: Reply with quote
The plastic base bit doesn't look big enough to hold the circuitry needed to run them direct from mains, I'd expect them to require an external ballast. Normally light fittings that take those types of lamps would have the ballast built in.
Test Passed 10/05/2011 Current bike: XJ6-N
t121anf
PostPosted: 22:33 - 24 Mar 2012    Post subject: Reply with quote
Read the questions Wink
at106
PostPosted: 23:15 - 24 Mar 2012    Post subject: Reply with quote
Thanks for your reply, looking around it appears you may be right.
Read the questions
I have but that doesnt mean, there arnt other components required.
Cunnington
PostPosted: 23:18 - 24 Mar 2012    Post subject: Reply with quote
If you plug them into something like https://www.screwfix.com/p/arden-eco-rectangular-18w-black-bulkheads/54892, they can run off mains electric.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
iooi
PostPosted: 12:50 - 25 Mar 2012    Post subject: Reply with quote
Mmm...
Q: What voltage does the item below work off? Is it mains or 12-18V
Tony R - 21/02/2009
Answer to follow Wink
One does wonder about some people....... Rolling Eyes
Seb
PostPosted: 17:34 - 25 Mar 2012    Post subject: Reply with quote
The builders have fitted similar shitty fittings in my new pad (PLC 4 pin to be precise), the gubbins (ballast/Starter etc?) are housed in the light fitting itself. Utter gash, needless to say they will be coming down pronto Smile
2010 Triumph 1050 Sprint ST
Cunnington
PostPosted: 19:58 - 25 Mar 2012    Post subject: Reply with quote
Is it not a building control thing? - they want external lights to be capable of taking only low energy bulbs in the hope that they will save a few baby seals by stopping you fitting those very nasty incandescent light bulbs.
Seb
PostPosted: 21:25 - 25 Mar 2012    Post subject: Reply with quote
Nope, these horrors are actually indoors Shocked
Every ceiling fitting in the house uses one of those things Crying or Very sad
t121anf
PostPosted: 11:13 - 26 Mar 2012    Post subject: Reply with quote
iooi wrote:
Mmm...
Tony R - 21/02/2009
not sure what you are seeing but on my screen it says
Maplin says: they work off the UK standard mains supply
The last post was made 14 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 65.56 Kb
