| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 00:58 - 28 Sep 2004 Post subject: Is this a horribly obvious statement? |
My 10 year old eastern block 2 stroke doens't like being ridden flat out in top.
*cue laughter*
the bike rides nicely, but if I take it on a flat straight bit of road, flat out, it'll get to about 65, and it'll stay there for a minute or so, then it'll start acting up.
it'll suddenly slow like you've eased off the throttle or touched the brake.
obviously my first thought is that it's an early warning sign my engine is about to seize.
it happened today, and the engine did in fact cut out, why I'm not quite sure, everything happened quite quickly, and I was playing with gears trying to remedy the situation, but I did roll to the side of the road, where I kicked her over, and she was fine again.
It's quite happy doing 50mph, which I tried. No problems at all.
Is this obvious? Should I not push this kind of bike to these kinds of limits?
Gaz |
| stinkwheel |
 Posted: 01:44 - 28 Sep 2004 Post subject: |
First off, what bike?
Assuming it is a generic 125.
You will find that the world goes by at 55mph. They will do this all day long. However they shouldn't be doing what you describe, if it is a 125, 60 shouldn't be outwith the realms of possibility, a sustained 65mph on some of them will mean it is going to get hot though.
What you describe sounds like the engine tightening up, as you say, ready to seize (hey, at least they give you plenty of warning).
Couple of questions:
Does it have a fairing? some models were fitted with full fairings that only have a small hole in to let air get to the engine. These cause them to seize up on-piece.
What 2-stroke mix are you using? Most (mz, jawa, cz, various soviet) are designed to run at 40:1, later models will state 50:1 or even 60:1 as they failed european emissions tests otherwise. Oil pumps on these bikes can be very hit or miss (some jawa oilmasters have been known to put out down to 70:1 when the marks are aligned), try richening up the mix a bit, the worst that can happen is it will need a de-coke sooner. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wave2k |
 Wave2k G's Stalker
| Frost |
 Frost World Chat Champion
| Mr C |
 Mr C World Chat Champion
| Robin |
 Robin Scooby Slapper
 Posted: 14:01 - 28 Sep 2004 Post subject: |
Looks like you've hit top speed mate
If it is starting to complain it obviously aint happy. Might need some general maintenance on the engine, try whipping the head off and checking the piston, and bore, also look for carbon build up.
My MZ250 went for about 400 miles slowly losing a bit of power until it siezed solid on the A1. The small end bearings had worked their way up the side of the piston and were bouncing about in the chamber.
Other wise just accept that this is top speed for that bike. |
| Gazdaman |
| Kickstart |
 Kickstart The Oracle
| Gazdaman |
| Gazdaman |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
The last post was made 21 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
