peugeot speedfight 2 100cc just bought only hits 40!
tman8686
PostPosted: 21:04 - 28 Mar 2012    Post subject: peugeot speedfight 2 100cc just bought only hits 40! Reply with quote
hi people thanks for looking at this post i hope someone can help me, i have just purchased a speedfight 2 100cc o2 plate the bike was a project off of someone he moved and i bought it,its fine in good nick works fine everything only prob is it only hits forty and revs like mad once it gets there what could this be? ive got it in parts ready to do whatever hopefully! ppplllleeeeaaaasssseeeee heeellppp
PLLLLEEEEEEEEAAAAAAAAAASSSSSSSSSSSSSEEEEEE HHHEEEEEEEEELLLLLLLLLPPPPP
stevo as b4
PostPosted: 21:20 - 28 Mar 2012    Post subject: Reply with quote
New belt and rollers needed i would say!
Also clean up the variator mech and check the faces of the pulleys for scoring or damage. use some VHT grease on the variator centre bearing/bush on reassembly.
tman8686
PostPosted: 21:27 - 28 Mar 2012    Post subject: Reply with quote
ok so what size /wieghts shall i get? and how do i do the variator thing where is that located? whats it look like?
MyCarVsYourHe...
PostPosted: 15:43 - 29 Mar 2012    Post subject: Reply with quote
How many miles are on this thing? you may need to replace the piston rings, and maybe the piston. You should get these parts from a breakers yard for less then half the price of new, just ask how many miles they have on them, the guy I go to would say (I pulled this from a bike with less than 5k miles on it). It would be a good idea to replace the belt as well because as it wears it changes the gear ratio slightly. If your rollers have developed flat spots this may also affect your top speed so pick up some replacements, new not used. Replace the spark plug, clean the carb and it's jets, remove the exhaust and get ride of any carbon build up on the end that connects to the engine, pump up your tires, and if it's still slow then your probably going to need a new clutch system, Either that or it's actually a 50cc engine..
PostPosted: 16:23 - 29 Mar 2012    Post subject: Reply with quote
LOL wot? Engine rebuild with second hand parts? A quick look suggestion you can get a new Cylinder/piston for Less than £90. It doesn't need it by the sounds of it. I'm not scooter expert but if it is pulling to a point then revving up with no more acceleration it is a problem on the drive train, something is slipping, clutch or the belt.
The last post was made 14 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 50 Kb
