Starts fine when dry, but the morning dew trumps it
borgy95
PostPosted: 11:26 - 29 Mar 2012    Post subject: Starts fine when dry, but the morning dew trumps it Reply with quote
Hi BCF,
Sadly my first post on this forum is a troubleshooting one! hopefully more pleasant ones will follow!
I recently bought a 1992 GPZ500s.
As the title suggests the bike starts really well when its dry so anytime after about 11 when the morning dew has gone and the sun is out.
But whenever i come to start it for my journey to work around 8.30am it is really unrelaible and sometimes plain refuses to start...
This suggests to me damp in a connection? what do you all think?
if it is how do i remedy this?
(i know very little about bikes this is only my second one, and i've only been riding about 6-7months now and had no issues with my previous one ever.)
PostPosted: 11:43 - 29 Mar 2012    Post subject: Reply with quote
Does sound rather like there's damp somewhere.
Does it turn over ok?
Two places to check for problematic connections on a GPZ500.
1) Main fuse holder. This is located on the starter solenoid. Follow the fat wire from the battery positive, it attaches to the solenoid under the ?left? side panel. There is a snap connector attached to the top of it, under which is a 30A fuse. Check the terminals and ends of the wires in this snap connector for signs of corrosion (green and furry, damaged contacts, wire may pull out of terminal when waggled). I've had three of these fail in exactly the same place.
2) In the ignition switch itself. It makes and breaks a few different connections. It's possible for it to fail in such a way as the lights come on and the starter motor turns but you don't get a spark. Look for the rev counter needle moving slightly as you turn it over. If it doesn't, you probably don't have a spark.
Spray a load of WD40 down the switch, give the key a good wiggle about and try again. If this fixes it, the switch is on its way out, buy a new one. I've also had three of these fail in this exact way.
PostPosted: 11:47 - 29 Mar 2012    Post subject: Reply with quote
Using the choke?
Do you leave your bike outside under a cover or in the open?
borgy95
PostPosted: 14:44 - 29 Mar 2012    Post subject: Reply with quote
##Paddy## wrote:
Using the choke?
Currently in the open, haven't got round to buying one yet, it's part of my weekend plan.
@stinkwheel Ace, just the kind of details a know nothing like me needs... lets hope the weather holds out for the w/e ill do the checks etc.
But to answer your question the engine is turning over fine... and when it is running all is sweet as sugar.
steven_191
PostPosted: 16:37 - 29 Mar 2012    Post subject: Reply with quote
sounds like your choke circuit. If you have a manual choke that is??
if so you could unbolt it from the carbs and make sure that when you pull the choke lever it physically pulls the cable and opens the circuit.
dont use the throttle when using the choke. If you have to use the throttle, your choke circuit probably needs tuning to suit the bike.
borgy95
PostPosted: 10:38 - 30 Mar 2012    Post subject: Reply with quote
Thanks for the help guys...
Figured out what the issue was... a combination of things...
One was the battery not holding enough charge so that needs replacing..
two is my inexperiance using a choke, and making it harder for the engine to start.
and i took a thrid precaution by wd40'ing the connections... as stinkwheel suggested.
i will continue to generally observee starting performance to see if there may be anything more serious going on
again thanks
The last post was made 14 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 48.24 Kb
