| rubberhedgeho... |
 rubberhedgeho... Borekit Bruiser
| la_lucha |
 la_lucha Scooby Slapper
| UrbanRacer |
 UrbanRacer World Chat Champion
| Gazz |
 Gazz World Chat Champion
 Posted: 12:10 - 29 Mar 2012 Post subject: |
What I do is check for any entrances on the right side of the road that none of the cars in front will be turning into and also look for the biggest gap between the cars (all the cars wont be travelling at exactly the same distance apart). And I aim for this point instead of trying to take all the cars in 1 attempt. If you need to pull in then do it here but if you can do them all in 1 go then go for it. Also keep an eye out for the second car from the front who might also be looking to overtake the first vehicle (but obviously watch all the cars. However usually cars only overtake 1 vehicle at a time so it is most likely the 2nd car who will pull out on you as you attempt to pass that).  |
| soforene |
 soforene Nearly there...
 Posted: 12:14 - 29 Mar 2012 Post subject: |
You should always have your entry point in sight when overtaking.
This can move as your view opens up but not having a safe point to get back onto your side of the road may lead to a nasty situation.
Hang back and use the acceleration of your bike to get safely past vehicles when appropriate.
With the speed of bikes these days you'll probably only be "delayed" a few minutes at most so don't do anything rash and regret it halfway through the manoeuvre.
It's your ass on the line.  |
| J0Al1 |
 J0Al1 World Chat Champion
| Acemastr |
 Acemastr World Chat Champion
| Cheeseybeaner |
 Cheeseybeaner World Chat Champion
| ceekay |
 ceekay Nova Slayer
| Frost |
 Frost World Chat Champion
 Posted: 13:45 - 29 Mar 2012 Post subject: |
If they're going fast then they'll be leaving enough space between each other for a bike to slot into. If they're nose to tail it'll be because they're stuck behind something slow like a tractor. In that case you have to make a judgement call of whether you can overtake the lot or wait till a few have overtaken the tractor first.
If in doubt don't be afraid to push in. Get as far in front of a car as possible, slow down to match their speed to give them chance to see you and lean on them till they slow down / move over. The car coming the other way will also see you and move to the left which will very probably give you room not to get hit head on even if the car doesn't left you back into the left. It's not something you want to be doing day to day, but doing it has got me out of the shit a few times, like when the car coming the other way is going double the speed limit you suddenly find you've not enough space to over take
Something to be very careful of when overtaking multiple cars, and that's those cars you're passing attempting an overtake. I had it a little while back, a queue for 4 cars behind a tractor. I waited for the cars to pass it as we went down a straight, none did. The next straight i started to overtake only to have one of the cars swerve into my path as it attempted an overtake. |
| Sako |
 Sako World Chat Champion
| Ichy |
 Ichy World Chat Champion
 Posted: 13:55 - 29 Mar 2012 Post subject: |
I do multiple overtakes a lot and it is one of the things that requires experience and confidence. Yes, the safe answers are correct but it's easy to get carried away sometimes and find youself in these situations. The main consideration is that you should treat each car as a seperate overtake. Do everything you can to ensure that they are aware that you are there.
Personally, if I need to pull in, I use hand signals to show my intention. I deliberately look over my left shoulder to check that they have noted and I start to move in. When I pull in I give them a little thank you wave. Works for me. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| alun111 |
 alun111 World Chat Champion
| Cheeseybeaner |
| Kwaks |
 Kwaks I'm not a fast rider
 Posted: 17:52 - 29 Mar 2012 Post subject: |
cars don't tailgate bikes that move to the middle of the road so that they spray crap up behind them. ____________________ Fallen Angel "Nae sniffing my seat now!!!!! "
www.cliqueycuntsmcc.co.uk
I AM NOT A FAST RIDER!!!!!!!!! |
| daesimps |
 daesimps Scooby Slapper
| Pete. |
 Pete. Super Spammer
 Posted: 18:36 - 29 Mar 2012 Post subject: |
I found out the hard way when I was a youth that if there's a queue of cars with the front one going slow there's a good chance he's going to turn right. I landed on his bonnet with the wing all stoved in. Make sure there are no right turns - or left ones that another vahicle can nip out of - in front of the rolling queue. ____________________ a.k.a 'Geri'
| rubberhedgeho... |
 Posted: 19:13 - 29 Mar 2012 Post subject: |
Thanks for all of those tips.
I am well aware of the dangers of cars turning right - rode past a scene where someone decided to overtake a petrol tanker on the right just as it turned into the petrol station. His head was approximately 10 feet away from his shoulders.......
I'm not going for the overtakes when there is oncoming traffic, just sometimes there is bunching with multiple cars that aren't going THAT slowly but still spoil the fun for some corners.
I supposed holding back probably won't get me killed, and it's always better safe than sorry. At least now the weather is warm so I can open the visor and cool down a little bit  |
| J.M. |
 J.M. World Chat Champion
| fozzym |
 fozzym Brolly Dolly
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| Rob W |
 Rob W World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 22:14 - 29 Mar 2012 Post subject: |
I use my horn quite a lot riding around town. Usually for pedestrians though, especially outside Waterloo station - they all seem to be indestructable. ____________________ a.k.a 'Geri'
| soforene |
 Posted: 22:15 - 29 Mar 2012 Post subject: |
Don't forget chums, a flash of Main Beam means the same as the horn.
i.e. Yoohoo!! I'm here !!
If I'm going for a multiple overtake then I might pull out and then give a blast of Main Beam as I accelerate.
It may make all the difference between a safe overtake and a SMIDSY ...........  |
| Llama-Farmer |
The last post was made 14 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
