| newmannewy |
 newmannewy Borekit Bruiser
| P.addy |
 P.addy Red Rocket
| chris-red |
| newmannewy |
| chris-red |
| stonesie |
 stonesie World Chat Champion
 Posted: 14:46 - 29 Mar 2012 Post subject: |
I can do a 'Quick re-set' on my management light on the Daytona 650...
Warm it up to about 80°C
Turn it off and count to 5
Turn it back on and let the dash go through it's routine and the fuel pump prime, count to 5
Repeat 3 times
Start it up and admire the management light telling you all is well
When the dash starts up it shows the coolant temp as 'LO' then shows the proper temperature... as far as the ECU is concerned that is a heat cycle  |
| oily85 |
 oily85 Derestricted Danger
 Posted: 15:31 - 29 Mar 2012 Post subject: |
If it does come up with an engine management light, with a £10 cable from ebay, a bit of setting up drivers and Tune ECU from www.tuneecu.com, you can see what exactly the error code is and clear all codes from the memory. |
| newmannewy |
 Posted: 15:52 - 29 Mar 2012 Post subject: cheers |
Thanks folks for the encouraging input.. I might just go clear the garage out to make a bit of space..
And thanks for that link to software oily I did wonder if I could get the software anywhere..  |
| newmannewy |
| chris-red |
| MarJay |
 MarJay But it's British!
The last post was made 14 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
