| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 17:58 - 29 Mar 2012 Post subject: Newbie maintenance questions |
I'm a bit paranoid about maintenance -- mostly because I'm brand new with motorcycles and also because I'm a mechanical ignoramus....
I bought the haynes manual for my new bike (CBF125). The bike I have is basically new (only a few miles on the clock before I got it), so I'm starting with a fresh slate and need to have it fairly regularly serviced by professionals anyway (for the warranty book).
However, there are lots of things I guess I'm supposed to do weekly or so that I'm aprehensive about. Some questions off the top of my head:
* The chain seems to use a wax (not the oil described in the haynes manual), correct? The guy in the local shop sold me chain wax spray and a chain cleaning spray. I also got a chain brush. How often should I clean this, really, assuming an average London-area commute of 100-150 miles a week in London weather (which is like Costa del Sol lately)? Do I clean the existing wax off (with the brush?) before I apply a new coat, or do I just use the brush/cleaner when the chain is especially dirty and just spray on some more otherwise? How often do people adjust their chain, roundabout? (I've done only about 400 miles, but the chain slack looks unchanged to me.) How paranoid do I need to be about getting the back wheel alignment exactly right if the chain needs adjusting?
* Tyre pressure. It seems harder to check motorcycle tyres than car ones, because of the size and angles, but I have found a guage that seems to fit (barely). How often do should I be checking the pressure? Has anyone used tyre pressure guards (the caps that turn green, yellow and red with pressure) and do they work?
* Cable lubing. The idea of taking something like the clutch cable *off* the bike, lubing it and putting it back on again makes my palms sweat... Really, how often will I have to go through such a scary exercise, roundabout, or can that wait for the usual service intervals? What kind of lube is used? |
| Ayrton |
 Ayrton World Chat Champion
| swampy |
 swampy World Chat Champion
 Posted: 18:22 - 29 Mar 2012 Post subject: Re: Newbie maintenance questions |
| esullivan wrote: |
* The chain seems to use a wax (not the oil described in the haynes manual), correct? The guy in the local shop sold me chain wax spray and a chain cleaning spray. I also got a chain brush. How often should I clean this, really, assuming an average London-area commute of 100-150 miles a week in London weather (which is like Costa del Sol lately)? Do I clean the existing wax off (with the brush?) before I apply a new coat, or do I just use the brush/cleaner when the chain is especially dirty and just spray on some more otherwise? How often do people adjust their chain, roundabout? (I've done only about 400 miles, but the chain slack looks unchanged to me.) How paranoid do I need to be about getting the back wheel alignment exactly right if the chain needs adjusting? |
If I were you doing that amount of miles, I'd give it a look over once a week or so. Wax is just a lubricant in the same way that oil is a lubricant, you can use either. Its worth cleaning your chain at the same time, as any road grit etc that sticks to the oil on the chain can cause wear. Use a brush and cleaner fluid, let the cleaning fluid evaporate (or dry off with a rag) and then reapply lube of choice.
Its worth checking chain tension at the same time. Your Haynes will tell you how much slack there should be, measured in the middle of of the bottom run of chain from sprocket to sprocket.
Alignment is something worth being pretty anal about (within reason) other wise your wheel will be on a diagonal and constantly trying to turn the back of the bike.
| esullivan wrote: | * Tyre pressure. It seems harder to check motorcycle tyres than car ones, because of the size and angles, but I have found a guage that seems to fit (barely). How often do should I be checking the pressure? Has anyone used tyre pressure guards (the caps that turn green, yellow and red with pressure) and do they work? |
Once again i'd check once a week, but look for any obvious punctures or loss of pressure before every ride. Never tried the guards, but don't see the point if you check regularly.
| esullivan wrote: | * Cable lubing. The idea of taking something like the clutch cable *off* the bike, lubing it and putting it back on again makes my palms sweat... Really, how often will I have to go through such a scary exercise, roundabout, or can that wait for the usual service intervals? What kind of lube is used? |
Usual service intervals will be fine, its not as hard as it seems - all you need to do is slacken the cable, remove from the lever end, make a little funnel of tin foil around the end of the cable and pour some 3 in 1 oil down it. Leave it so its as straight as poss over night, and re assemble... ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| neil. |
 neil. World Chat Champion
| recman |
 recman World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| Sako |
 Sako World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:23 - 30 Mar 2012 Post subject: |
| esullivan |
| Sako |
| esullivan |
| Ayrton |
| Sako |
The last post was made 14 years, 99 days ago. Instead of replying here, would creating a new thread be more useful? |
