Indicator PROBLEM!!! HELP!!!
King
Guest
PostPosted: 20:12 - 05 Sep 2002    Post subject: Indicator PROBLEM!!! HELP!!! Reply with quote
Cool Hi everybody. I think I have a serious problem. My bike is a Honda NSR125R 2001. Its great, but I think there is a problem with the indicator. When I indicate to go left the left indicatior works fine it flashes and the indicator on the display flashes too. Problem is it does not work on the right indicator, when i indicate to go right the right inidcator just lights up, and stays on, it doesn't flash, it just stays on, both the front and rear. I am not technically good with these things, but if somebody pointed me in the right direction, it would help, I could robably do it. Oh, if I cannot fix it, is the bike still legal?
Wingchunal
PostPosted: 20:13 - 05 Sep 2002    Post subject: Reply with quote
This happend to mine when one of the bulbs went!
Demonic69
The Pink Rhino
Bike is not legal if it don't flash. Check the wiring for the right hand indicators
Back on a Blade. Just feels so right.
King
Guest
PostPosted: 20:20 - 05 Sep 2002    Post subject: Reply with quote
Yeah, my bulb died, so I got a replacement, the one I took out was rated 2W the one i put in was 6W, but it works fine. The front indicator was still doing the same thing even without the bulb in the rear?
Wingchunal
PostPosted: 20:23 - 05 Sep 2002    Post subject: Reply with quote
Im sure nsr indicators are 10 wat
PostPosted: 22:01 - 05 Sep 2002    Post subject: Reply with quote
The wattage is relevant. The relay depends on a particular wattage of bulb. Get the wrong wattage and the bulbs will flash at the wrong rate, or not at all
King
Guest
PostPosted: 08:32 - 06 Sep 2002    Post subject: Reply with quote
Yeah, I replaced the long original indicators with mini indicators, but they worked fine, after about 1600km this started to happen. HELP!!!
Screaming Skull
PostPosted: 08:51 - 06 Sep 2002    Post subject: Reply with quote
I changed my indicators to mini ones last week.. drove up home thinking I was the dogs bollox, got to my house and realised the left one hadn't been working since I left my mates Embarassed . Turns out one of the wire connections had detached itself some how
Screaming Skull
Doesn't matter how well you do, as long as you look good!!!
Kris
PostPosted: 08:58 - 06 Sep 2002    Post subject: Reply with quote
I changed mine to mini-indicators....but couldnt be arsed to get a new relay. Had no indicators for 3 months Embarassed
www.prisonplanet.com
PostPosted: 09:10 - 06 Sep 2002    Post subject: Reply with quote
'cmon you lot... you've got arms, haven't you? Smile
G1_
PostPosted: 09:36 - 06 Sep 2002    Post subject: Reply with quote
they have arms, but you get the impression that they got nothing in their heads Razz
King
Guest
PostPosted: 11:20 - 06 Sep 2002    Post subject: Reply with quote
C'mon guys, can somebody just tell me how to fix it. What is the relay? I have connected all the wires, but I think its something else. HELP!!!
PostPosted: 11:29 - 06 Sep 2002    Post subject: Reply with quote
First, if it's a 2001 model it should still be under warranty... so get it sorted through that.
All the times I've only had one indicator left on without flashing it's been because there was a broken connection somewhere, though I'm sure there's other things that can cause this.
I haven't had working indicators on my bike for a while I just use arm signals... I'm not sure about the legality of having indicators that don't work though. (you can still get an MOT if you don't have indicators however).
King
Guest
PostPosted: 13:02 - 06 Sep 2002    Post subject: Reply with quote
Its still under warranty, but I will have to go to liverpool to sort it out. I want to fix it, so if you told me how, I can probably do it.
Zimma
Wheelie Junkie
PostPosted: 13:07 - 06 Sep 2002    Post subject: Reply with quote
i dont think you legally have to have indicators, the thing you have to have is brake lights and head lights Smile so fu*k the indicators and use your arms Very Happy
seriously tho... its probably the wrong wattage bulb that is causing the problem... change it Smile
-Zimma
PostPosted: 13:11 - 06 Sep 2002    Post subject: Reply with quote
I presume it's not uk spec (cos then you could get it done at any authorised Honda garage).
If it is something more serious and you managed to mess it up they could refuse to fix it under the warranty.
[reads up^]
ah.. they could make trouble cos you swapped the indicators
nm
Bhaal85
PostPosted: 13:16 - 06 Sep 2002    Post subject: Reply with quote
I am Bhaal85 a.k.a King, the bike is an import from Holland.
WildGoose
White Van Man
PostPosted: 16:42 - 06 Sep 2002    Post subject: Reply with quote
its an offence to have indicators fitted that dont work
so if you have them and start using your arms expect to be pulled
plus indicatin right with your arm is a bitch
PostPosted: 17:36 - 06 Sep 2002    Post subject: Reply with quote
'sorry officer.... just noticed they stopped working so I'm using arm signals while I get it to a mate's house to get it sorted' Smile
The last post was made 24 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 92.52 Kb
