Spark plugs
FerretFing
PostPosted: 15:58 - 30 Mar 2012    Post subject: Spark plugs Reply with quote
Just bought the wife a Yamaha Mt-03 (2006) & in the process of doing a service on it noticed there was a different spark plug in there - NGK CR8EIX - compared to the proper one (according to service manual) that I'd bought - CR7EIX....what would the difference between the two be & could it have caused any problems with prolonged use? Thanks.
temeluchus
PostPosted: 16:10 - 30 Mar 2012    Post subject: Reply with quote
the heatr range governs the self cleaning properties of the plug and the manufacturer matches it against the conditions in the motor to get the ideal properties.
It is not uncommon to have different heat ranges used in one model to match differing fuelling, local conditions and intended use.
One heat range difference may not make a big change and as you are installing the recommended plug I would think you would be ok. The old plug is unlikely to have caused any issues.
0l0dom0l0
PostPosted: 17:04 - 30 Mar 2012    Post subject: Reply with quote
The cr8eix is a cooler plug than the cr7 you've bought.
If the manual says you should have the cr7.. you'll be fine.
It is slightly more important on 2 strokes but for that I wouldn't worry.
The last post was made 14 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 35.46 Kb
