Heated grips playing up
EazyDuz
PostPosted: 14:01 - 30 Mar 2012    Post subject: Heated grips playing up Reply with quote
So i have these:
https://www.ebay.co.uk/itm/ROXTER-WINTER-MOTORCYCLE-MOTORBIKE-HOT-HEATED-BAR-GRIPS-/390129703475?pt=UK_Motorcycle_Parts&hash=item5ad58ada33
And they have been fine since i fitted them but suddenly playing up.
yesterday i removed the left grip as it had come unstuck, stuck it back on and today the RIGHT grip isnt working properly. It comes on and off, loose connection im assuming.
Put a voltmeter on the tamiya connector from the main control unit, and its getting power, even wiggling the connection and its still getting power, so the issue must be the connection on the grip side.
Any idea what i can do? Ive sprayed WD40 down the tamiya connector thinking it might have got corroded but it looks fine, left one works perfectly...
Atomic Punk
PostPosted: 15:32 - 30 Mar 2012    Post subject: Reply with quote
Why are you using heated grips in this weather???
I may have lost my way but I'm way ahead of schedule.
EazyDuz
PostPosted: 15:52 - 30 Mar 2012    Post subject: Reply with quote
Cuz it was 8C this morning
instigator
PostPosted: 16:10 - 30 Mar 2012    Post subject: Reply with quote
Eat some porridge in the morning, ya big jessie.
In all honesty? I'd bin them. If its a fault contact in the grip, you'll have to tear them apart to reconnect it. Pity, they look like the same type as Oxford grips just cheaper, shitter ones.
janner_10
PostPosted: 18:07 - 30 Mar 2012    Post subject: Reply with quote
Oxford are cheaper than these odd make - as mentioned throw away and get an oxford pair - least you have 6 months to do it.
EazyDuz
PostPosted: 18:12 - 30 Mar 2012    Post subject: Reply with quote
Nevermind they seem to be working againn now, sprayed ACF50 in the connections and it seems to have worked. If it happens again ill take the control unit apart, there could be a loose connection there.
They are budget yea, but work very well.
goto10
PostPosted: 22:39 - 30 Mar 2012    Post subject: Reply with quote
I have the same ones - they come with a year's warranty, my control box went slightly iffy but it was all sorted very quickly - the seller is very good and will exchange it for you if there's a problem. (Assuming it's still <1 yr)
WULFSTAN
PostPosted: 22:51 - 30 Mar 2012    Post subject: Reply with quote
cold this morning Rolling Eyes come back in feb when the ignition on your bike is soild ice and u have to warm it up before you can get the key in
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
goto10
PostPosted: 23:59 - 30 Mar 2012    Post subject: Reply with quote
It's the same gear, just rebranded.
Chris750
PostPosted: 00:29 - 31 Mar 2012    Post subject: Reply with quote
Oxford make both (they make lots of other brands for company's that you would never realise was them also). I would guess they sell their latest/best stuff under their own name and only give support/warrenty with the Oxford stuff also.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
sickpup
Old Timer
PostPosted: 15:05 - 31 Mar 2012    Post subject: Reply with quote
Yeah I agree, the sort of weather where one might need to use handlebar muffs...
EazyDuz
PostPosted: 15:40 - 31 Mar 2012    Post subject: Reply with quote
I was riding in feb too, but i didnt face that problem as i keep it garaged.
WULFSTAN
PostPosted: 15:41 - 31 Mar 2012    Post subject: Reply with quote
haha Laughing
WULFSTAN
PostPosted: 15:43 - 31 Mar 2012    Post subject: Reply with quote
i refuse on principle to ever use muffs after all the shit ive said about them tho i agree they do keep your hand a lot warmer
sickpup
Old Timer
PostPosted: 15:53 - 31 Mar 2012    Post subject: Reply with quote
Well in your case the advantage is that when you get home with your numb frozen hands you can have a wank while pretending it's someone else. Wink
HTH Thumbs Up
WULFSTAN
PostPosted: 15:55 - 31 Mar 2012    Post subject: Reply with quote
HTH Thumbs Up
now you see why i dont use them Laughing
EazyDuz
PostPosted: 17:22 - 31 Mar 2012    Post subject: Reply with quote
Ever heard of multiquote?
WULFSTAN
PostPosted: 17:29 - 31 Mar 2012    Post subject: Reply with quote
wow big man you ever heard of who cares ?
The last post was made 14 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 100.45 Kb
