Pure Genius or Complete Idiot ??
newmannewy
PostPosted: 23:04 - 30 Mar 2012    Post subject: Pure Genius or Complete Idiot ?? Reply with quote
Ok so I need to adjust the valve clearances on my Triumph Daytona 955i ..
Now my daytona only has a side stand & I do not posess a centre stand. Now in order to avoid the cost of purchasing a paddock stand (£100+) in order to rotate the back wheel whilst I adjust and measure the valve clearances.. I was wondering could I keep the bike on the side stand and spin the wheel using a "laser wheel spinner"
as pictured here: https://www.machinemart.co.uk/shop/product/details/laser-5320-motorcycle-wheel-spinner?da=1&TC=RV-050915320
What are you thoughts guys.. Completly dumb idea.. or might just work ? Mr. Green
Also does anybody know a cheap place to get shims from. As they seem rather expensive for just a small disc of metal.
PostPosted: 23:06 - 30 Mar 2012    Post subject: Reply with quote
Buy or borrow a paddock stand. If the bike falls over whilst doing the valves you'll be in a world of pain.
Sako
PostPosted: 23:07 - 30 Mar 2012    Post subject: Reply with quote
paddock stands are under £50 for a pretty decent one mate.
J.M.
PostPosted: 23:12 - 30 Mar 2012    Post subject: Reply with quote
<£50 for front and rear:
https://www.ebay.co.uk/itm/BikeTek-Universal-Motorbike-Motorcycle-Front-Rear-Lift-Paddock-Stands-Pair-Set-/190652980789?pt=UK_Motorcycle_Parts&hash=item2c63cd9e35#ht_2710wt_1199
2004 R1 & 2018 XSR900
temeluchus
PostPosted: 23:20 - 30 Mar 2012    Post subject: Reply with quote
nick a milk crate.....
Frost
PostPosted: 23:21 - 30 Mar 2012    Post subject: Reply with quote
You can probably turn the engine over using the nut that holds the flywheel on. I've done valves with a bike on a side stand, but then i've never owned anything too expensive to worry about wrecking Laughing
hornetmike
PostPosted: 23:27 - 30 Mar 2012    Post subject: Reply with quote
Do it this way, works on every other bike I've owned
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
too fucking right. I bought a paddock stand for under £30 on ebay. Don't take shortcuts, it can become very expensive.
0l0dom0l0
PostPosted: 00:35 - 31 Mar 2012    Post subject: Reply with quote
Can turn the engine over using a socket as above.
Chris750
PostPosted: 00:36 - 31 Mar 2012    Post subject: Reply with quote
I am near Oxford, as long as I got it back, I would happily lend you my rear stand.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
J4mes
PostPosted: 08:10 - 31 Mar 2012    Post subject: Reply with quote
I paid £22 for my rear stand, and then someone posted after me to say the same model was available for £15. It holds my thundercat up nicely, plenty strong and stable enough.
One of these https://www.ebay.co.uk/itm/BIKETEK-HEAVY-DUTY-REAR-MOTORBIKE-PADDOCK-STAND-LIFT-/260785231407?pt=UK_Motorcycle_Parts&hash=item3cb802d62f
Can be had cheaper than that though.
newmannewy
PostPosted: 09:38 - 31 Mar 2012    Post subject: single swingarm Reply with quote
Its a single sided swing arm - the stands are more expensive.
I also need to buy a :
Torque wrench £25 - 35
Micrometer £11
Valve Compresion Set ? To Lift Valves out - £55
If anyone near Wolverhampton has a padock stand for single sided swing arm daytona 955i & a valve lifting kit.. Id be more than happy to pay a rental fee Thumbs Up
Fisty
PostPosted: 09:51 - 31 Mar 2012    Post subject: Re: single swingarm Reply with quote
Please tell me you actually know what you are doing?
You do not need to remove the valves to do the clearances.
Fatter and faster than Fret
WULFSTAN
PostPosted: 10:14 - 31 Mar 2012    Post subject: Re: single swingarm Reply with quote
was thinking this myself
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
PostPosted: 11:00 - 31 Mar 2012    Post subject: Reply with quote
He means the shim tool. YOu can do the shims without pulling the cams, but the tool is £55. I could make on in an hour given the dimensions, it's a very simple device.
newmannewy
PostPosted: 12:44 - 31 Mar 2012    Post subject: shim tool Reply with quote
Thats right a shim tool, and no I aint got the foggiest about what im doing Razz
Although I do have a haynes manual and have read a few tutorials online. As with anything you want to learn in life - you have a go.
janner_10
PostPosted: 15:23 - 31 Mar 2012    Post subject: Reply with quote
Good luck then!
J4mes
PostPosted: 15:36 - 31 Mar 2012    Post subject: Re: single swingarm Reply with quote
Embarassed
stonesie
PostPosted: 17:46 - 31 Mar 2012    Post subject: Reply with quote
https://www.ricambiweiss.de/index.php/cat/c190_PADDOCK-STAND.html/XTCsid/mj6siah3p1p9p73fogjeifh3p4
Good quality TUV approved stuff for not much cash, just takes a few days to get in from germany Thumbs Up
newmannewy
PostPosted: 23:50 - 31 Mar 2012    Post subject: Reply with quote
Thanks for the link stonsie, but that still puts it over £60 with delivery. Im trying to avoid that cost. Probably wont be able to but im tryin.
Im gathering all parts & tools together before I attempt the job. Im wondering where is the best place to buy shims once I work out which sizes I need ?
Also does anybody have any recomendations for a good torque wrench. It seems the nm sizes are totally random.. From 3nm - 28nm or 40nm - 220nm or 5nm - 25 nm..
its like which wrench do you go for ? Why does it seem nobody makes sets like 0nm-25nm then 25nm - 80nm and 80nm-220nm or whatever.. why are they all random.
Noxious89123
PostPosted: 01:02 - 01 Apr 2012    Post subject: Reply with quote
Just buy one that covers th range you need.
This one covers a good range;
https://www.amazon.co.uk/Draper-34570-88-5-708-Inch-Pounds-Ratchet/dp/B0001K9T2O
If you need a bigger one for stuff like clutch centre nut or axle nut, get a big feck off one that does a higher range like this one;
https://www.amazon.co.uk/Draper-30357-Micrometer-Adjustment-Torque/dp/B0001K9S52/ref=pd_sim_diy_1
salty21
PostPosted: 08:03 - 01 Apr 2012    Post subject: Reply with quote
just pull the bike over onto its sidestand until the rear wheel lifts and turn the wheel by hand that way, aslong as your stood on the same side as the stand it shouldnt go anywhere
The last post was made 14 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.07 - MySQL Queries: 15 - Page Size: 115.51 Kb
