| mal180 |
 mal180 Derestricted Danger
| Teflon-Mike |
| mal180 |
 Posted: 16:43 - 31 Mar 2012 Post subject: |
I'd say TZR except they didn't sell the powervalve version as standard in the UK. It's certainly a 125 as it says so on the barrel. ____________________ a.k.a 'Geri'
| mal180 |
 Posted: 16:49 - 31 Mar 2012 Post subject: |
Thanks as i say the pics on google seem to be the same, what is the powervalve as i have no idea and have to try and get this engine going I have also posted this on several other forums with no reply so thanks alot for helping me out! |
| Bomberman |
 Bomberman World Chat Champion
| mal180 |
| Bomberman |
 Posted: 19:04 - 31 Mar 2012 Post subject: |
On the left of the cylinder head? That's the powervalve servo (edit, not servo just the valve :p) - that Haynes won't help you there as the UK bikes weren't fitted with them.
Thieved straight from a wiki on powervalves;
YPVS-Yamaha Power Valve System
YPVS Yamaha engines, Yamaha Power Valve System: Yamaha engineers realized that by altering the height of the exhaust port they could effectively change the engine power delivery thereby having optimal power and torque across the entire rev range, so it was that the YPVS was born. The valve is of a cylindrical design running across the top of the exhaust port, it is turned by a servo motor controlled from a control box taking information from the CDI (and other locations). The valve is a slightly ovular shape. This changes the height and size of the exhaust port at different engine speeds, maximizing the available power at all rev ranges. opening up firstly at 3k rpm for low end power, gradually in between 3-6k, fully opening at 6k rpm for maximum power,on most 125cc. It was fitted to all of the later models of the RZ/RD two-stroke road bikes (125, 250 350 and 500 cc), the TZR range.it was also added to the DT(125lc 2/3) range after 1984 (but was locked closed to comply with UK learner regulations until the(R) in 1988-04 which had a fully functional YPVS valve) the dt125r has a better design of engine,although not much altered in speed, just more reliable than its predecessor. The YZ series of motocross bikes has a mechanical power valve which is activated at RPM speed . The YPVS is only found on the liquid-cooled bikes not air cooled versions. Yamaha have also used a guillotine version in some of their later models such as the TZR250R SPR model..
Yamaha was actually the first company to produce consistent results with their YPVS in their race bikes. The 1977 OW35K was the first race bike to incorporate the power valve system and it won the Finnish GP in 1977. The Kadenacy effect was harnessed and controlled to a point that gave Yamaha great advantage over all the other manufacturers throughout the late 70's and into the mid 80's. The first street bikes with YPVS were the RZ/RD350 YPVS (LC2-onwards), and RZ/RD500 GP Replica in 1983-84. A ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare
 Posted: 19:05 - 31 Mar 2012 Post subject: |
Did you remove the plug? If not, going by the state of the fasteners I'd suggest pulling off the top and inspecting the internals. You might find rusted bearings and rings. ____________________ a.k.a 'Geri'
| mal180 |
| Bomberman |
| mal180 |
| mal180 |
| mal180 |
| Bomberman |
 Posted: 19:20 - 31 Mar 2012 Post subject: |
That's your two stroke pump under there. ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| mal180 |
| Bomberman |
 Posted: 19:26 - 31 Mar 2012 Post subject: |
| mal180 |
 Posted: 19:29 - 31 Mar 2012 Post subject: |
Good stuff, I have been wanting to buil a buggy for ages and this engine came up today for 50qiud and i thought i might as well thinking it was a 250cc lol but if i can get it going i will just use it! So if i have any more problems i know where to come cheers for the help guys! PS what mix of petrol to oil is it? |
| Bomberman |
| mal180 |
 Posted: 19:35 - 31 Mar 2012 Post subject: |
That was ok because i was going to ask about power valves as well! I will google again  |
| mal180 |
The last post was made 14 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
