peugeot vivacity engine problems?
sellmanbmx16
PostPosted: 22:23 - 31 Mar 2012    Post subject: peugeot vivacity engine problems? Reply with quote
hey guys, this is my first time on bcf Smile
anyway; i have a 2003 peugeot vivacity with 8000 miles on the clock, it starts and idles fine but will only occasionly actually rev high enough to move, this is a frequent problem and does not build up the revs. if on the rare occasion it does move it will only do this for about 30 seconds or so and then go back to not revving again, everything is standard on it.
Im at my wits end with this bloody bike so any guidance would be appreciated, thankyou!
Peugeot Vivacity 50cc 2003
sellmanbmx16
PostPosted: 22:40 - 31 Mar 2012    Post subject: Reply with quote
I r special wrote:
A good friend of mine had this issue, he simply phoned up peugeot and asked for a new Flux capacitor, they sent one out at a cost of £4.99.
you can go in the shop and get them to test it, the test is basicly riding it at excaly 88mph to see if it works.
good luck.
I'll get some plutonium ordered aswell
sellmanbmx16
PostPosted: 22:47 - 31 Mar 2012    Post subject: Reply with quote
I r special wrote:
wtf do you want plutonium for?
i dont think your taking this thread seriously, you muse be some kind of new age troll.
sure a flux capacitor was a time machine from back to the future ? haha Embarassed
MyCarVsYourHe...
PostPosted: 07:10 - 01 Apr 2012    Post subject: Reply with quote
Have you tried anything at all to resolve the issue? or is asking for help your first step to recovery? Laughing The first place I would look at is the throttle cable, detach it from the carburettor, usually just a single Philips head will do, pull the throttle out and see if the pin moves up and down freely, if so then I would move onto cleaning the carb, I would also drain the fuel tank and replace it with fresh fuel if I was you. when was the last time you changed your spark plug and do you have a decent tool box laying around?
ps how mechanically competent are you?
Usher4566
PostPosted: 07:45 - 01 Apr 2012    Post subject: Reply with quote
Check for air leeks around carb where joins head
New cd200 benly owner
Usher4566
PostPosted: 07:49 - 01 Apr 2012    Post subject: Reply with quote
Also tempary fuel starvation can cause revs to go up so yes clean carb make sure all jets clean.make sure carb on tight on bike .
Usher4566
PostPosted: 07:57 - 01 Apr 2012    Post subject: Reply with quote
sellmanbmx16
PostPosted: 11:17 - 01 Apr 2012    Post subject: Reply with quote
i have recently replaced the carb to manifold gasket and it is as tight as possible, and drained and put in new fuel. i have previously cleaned the carb though twice which didnt seem to resolve the problem. it has a brand new spark plug in it and ht lead. I am a car mechanic by trade so i am mechanically minded. this bike has just confused me abit Confused
MyCarVsYourHe...
PostPosted: 11:35 - 01 Apr 2012    Post subject: Reply with quote
Take a look at the condition of the reed valve, I've had similar issues to this due to a damaged reed valve block. Also have you checked to see if there's sufficient compression?
sellmanbmx16
PostPosted: 13:45 - 01 Apr 2012    Post subject: Reply with quote
theres seems to be a fair amount of compression, but when i took the reed valve off there was some metal shavings sitting on them and in the hole where the reed valve sits.
The last post was made 14 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 73.04 Kb
