could i use this speedo on my rs??
hadden
PostPosted: 20:42 - 31 Mar 2012    Post subject: could i use this speedo on my rs?? Reply with quote
hi all.looking into a digital speedo for my aprilia rs 125.its a 2000 model and has a cable speedo off the wheel.is it possible to change it to electric??love the look of this but there just the speedo problem.
https://www.ebay.co.uk/itm/DBR01-Multifunction-Digital-Speedo-Motorcycle-Custom-Chop-Streetfighter-/270936041560?pt=UK_Motorcycle_Parts&hash=item3f150be858#ht_2215wt_1110
also i have put renthal bars and im after some universal mounts.cant find anything decent just the usual cheap tacky shit of fleabay.has anyone had to buy a universal mount that is half decent?if so where did you get the bugar from??
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
WetSparks
PostPosted: 11:47 - 01 Apr 2012    Post subject: Reply with quote
Simple answer is if you can fit it, it will work.
If you notice, there is a section in the spec for selecting your wheel size. This means you will have to fix a magnet to the wheel, in the hub area. A pick up sensor mounted on the frame will then allow the speedo computer to count the number of revolutions per time period. With the wheel diameter set in the computer it can then work out your actual speed.
dextersaurus
PostPosted: 14:00 - 01 Apr 2012    Post subject: Reply with quote
Fantastic speedo, that.
It has 4 lights, neutral, indicators, oil pressure and full beam.
The speedo part is via 6 magnets put into the disk bolts, and a sensor taht you put on the fork leg, which picks up the magnet, and when you punch in the diameter of your wheel and the like, it gives you the reading.
The rev counter is done via the coil. you just plug the cable in and you're sorted.
It's also got a fuel guage, not sure if the RS has one or not.
Like i said, it's a good speedo and it works VERY well. see this video for the one i had on my GPZ 'fighter!
https://www.youtube.com/watch?v=pns9YLRvyEQ
Also, what kind of universal mounts you after? bars or lights? i've got both i could send you Thumbs Up
Cheers
Dunc
hadden
PostPosted: 21:13 - 01 Apr 2012    Post subject: Reply with quote
im after speedo mounts.2 off if you have 2.and if you have you will be hailed a king!send me some piccys if you can and if there the right ones just name your price.i don't do anal tho Smile
dextersaurus
PostPosted: 22:01 - 01 Apr 2012    Post subject: Reply with quote
you do realise that this speedo clamps right onto the handlebars, right?
Don't think i've got speedo mounts, i've got mounts to bolt onto the yoke for the bars, and a set that clamp onto the forks for the headlight. never know though, got a box full of streetfightery parts.
Dunc
hadden
PostPosted: 22:20 - 01 Apr 2012    Post subject: Reply with quote
iv got the mounts for the light which comes off the forks.i like the digi speedo but i was only gettin it if i can make the ones i have already got to fit properly.when u next get a spare minute have a look through your streetfighter bits and send me some piccies.need some universal mirrors if you have any.im using bar end indicators though so they cant be bar end mirrors.
The last post was made 14 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 49.8 Kb
