chain problem
davedjg
PostPosted: 12:57 - 02 Apr 2012    Post subject: chain problem Reply with quote
I have just had my lads bike fail its mot because there is supposed to be a rubber spacer or something between the chain and the underneath, asked the local bike shop they looked at me as if I was mad.
Does any one know what they are called or where I can get one from or how to fit them because I cant see where they would fit.
By the way its a chituma cg 125 copy of a honda
PostPosted: 13:13 - 02 Apr 2012    Post subject: Reply with quote
Get old innertube and cut it, fold it and glue it on Laughing Super bodge
Taught2BCauti...
PostPosted: 13:18 - 02 Apr 2012    Post subject: Reply with quote
I think the part you are looking for is called a 'Chain Guide' or 'Chain Slider' but I can't see one listed anywhere for your bike.
Are you sure it should have one? Not all bikes have them.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
davedjg
PostPosted: 13:30 - 02 Apr 2012    Post subject: Reply with quote
think it had chain gaurd on origanly still got top half on , some one told me still needed this rubber even with gaurd though, innertube sounds good idea will that work for mot ??
the other problem I have is I had to secure clocks but when I did this I broke spedo needle off is it ok to impovise ang glue something else on
PostPosted: 13:36 - 02 Apr 2012    Post subject: Reply with quote
Yea, just be ghetto for the MOT and stick a cocktail stick on there with a dab of glue, take it off and replace it later Thumbs Up
davedjg
PostPosted: 18:49 - 02 Apr 2012    Post subject: Reply with quote
does any one know if its ok to cut a piece of rubber and cable tie it on as replacement for chain guide , Does it need to be a min thickness ?
Taught2BCauti...
PostPosted: 19:18 - 02 Apr 2012    Post subject: Reply with quote
You would be better off fitting the correct part - try:
Chituma 125 Chain Guide on eBay
Breaking Chituma 125 for spares
Chinese bike spares specialist
You might find other makes are similar - like Lexmoto, Hongdou, Apache, Sukida, etc.
EazyDuz
PostPosted: 20:35 - 02 Apr 2012    Post subject: Reply with quote
i swear my bike doesnt even have one, will check tomorrow...
PostPosted: 20:45 - 02 Apr 2012    Post subject: Reply with quote
No you can't cable tie it on - the chain will tear off the cable tie. The MOT tester would die laughing whilst waiting for the fail cert to print out.
DrDonnyBrago
PostPosted: 20:46 - 02 Apr 2012    Post subject: Reply with quote
The speedo needle shouldn't actually fail the MOT I don't think, it certainly isn't tested and I had my last MOT without a working speedo.
As for the chain guide, are there holes in the underside of your swingarm that it would screw/pop into? Personally, I'd just "paddy" one together on the cheap out of a strip of rubber/bicycle tyre.
Nick 50
PostPosted: 20:59 - 02 Apr 2012    Post subject: Reply with quote
I really wouldn't bodge it to be honest. It is there to protect the chain rubbing on the swing arm which would degrade the chain pretty quickly.
What they are on about is:
https://www.chinesemotorcyclepartsonline.co.uk/images/largeimages/1100.jpg
you can get one from:
https://chitumaparts.chinesemotorcyclepartsonline.co.uk/partno_30216_1100.php
You will need to take the swing-arm off to fit it. It should be fixed to the swing-arm usually by screws. I doubt the part comes with them though so you will probably need to source your own.
If you get stuck where it goes give me a shout and i'll do a mock drawing or something.
PostPosted: 22:31 - 02 Apr 2012    Post subject: Reply with quote
I have my own mechanical term. Awesome Cool
davedjg
PostPosted: 06:41 - 03 Apr 2012    Post subject: Reply with quote
Cant seem to find where that part would fit so a drawing would be great if it is not to much trouble, not sure if its the same one for my bike I have the chituma cg 125 acording to the link this looks as though it comes from a scooter, I have mailed them to see but am waiting for reply,
The last post was made 14 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 76.26 Kb
