MOT Time... need new disk
PostPosted: 12:57 - 02 Apr 2012    Post subject: MOT Time... need new disk Reply with quote
Right, MOT is due in a week n a bit.
Forks are leaking a little, this can be solved simply by rebulding them, no worries.
Problem is my front right disk is rattly...the other is within spec by far. In theory I could convert it to a single disk Shifty but would that pass the MOT given the wheel has twin disk holes?
Obviously its not a permanent thing... just for the 30 minute MOT... mainly till I can afford a new disk (looking to be next month)
The joys of expensive parts Laughing
thomp1983
PostPosted: 16:58 - 02 Apr 2012    Post subject: Reply with quote
fork seals will pass aslong as it's not leaking enough to get onto brakes a light smear on forks will be fine.
are the brakes playing up? if it still brakes true it will probably pass the brake test fine, the disc being noisy shouldn't be a failure unless by it being rattly you mean it's loose in some way?
chris
PostPosted: 17:18 - 02 Apr 2012    Post subject: Reply with quote
Someone on here told me to put a bolt through the disc rivet and tighten a nut on it not only will then clamp it down it should also grip and spin the rivet freeing it up. Thumbs Up
whitedevil
PostPosted: 17:23 - 02 Apr 2012    Post subject: Reply with quote
+1 to what chris said, also spray with brake cleaner while you do it.
They are supposed to be loose so the disc can float.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
PostPosted: 22:41 - 02 Apr 2012    Post subject: Reply with quote
Hmm, good idea. Was going to be ghetto and just put something like a bit of rubber around the disk and squish it in the vice... Laughing
PostPosted: 07:17 - 03 Apr 2012    Post subject: Reply with quote
Single disk conversion will fail an MOT because the braking system has to be nominally as it left the factory.
PostPosted: 08:46 - 04 Apr 2012    Post subject: Reply with quote
So if it was a single disk to start with and you converted to a twin disk.. thats fine?
The last post was made 14 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 60.95 Kb
