don't use superglue
Gazza M
PostPosted: 12:22 - 06 Apr 2012    Post subject: don't use superglue Reply with quote
cautionary tale for ya.
i fitted some heated grips the other day to the bike (tired of chilly hands) and decided it would be a good idea to stick the right grip to the throttle tube using bog standard super glue. thing was fine for 100 miles or so - today i got real confused when the revs suddenly dropped to idle. pulled over, and the grip was just turning over the tube! only then i remembered superglue isn't fantastic at bonding to nylon... don't reckon heat from the grips/heavy wrist helped either...
luckily managed to find a nice bloke in a nearby house that had some araldite... stuck that to it and sat around for an hour waiting for it to cure!
at least the sun's out Smile
Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike
EazyDuz
PostPosted: 12:40 - 06 Apr 2012    Post subject: Reply with quote
I used hair spray and superglue on my throttle grip, been on there since November and hasnt come unstuck.
Used hair spray only on the other grip, which came unstuck last week so i put it back on with more hair spray and superglue, so far so good...
janner_10
PostPosted: 12:47 - 06 Apr 2012    Post subject: Reply with quote
I used the stuff that came with them - been 6 months so far.
Sako
PostPosted: 12:54 - 06 Apr 2012    Post subject: Reply with quote
good tip is to use spraypaint when putting on grips - sets extremely strong once set - if you are using renthal grips remember to get them lockwired for extra protection against slipping.
andym
PostPosted: 12:58 - 06 Apr 2012    Post subject: Reply with quote
Not sure I'm understanding what you mean with the glue and sprays... I've always just put insulating tape round the bars then forced the grips on and never had a problem...
Sako
PostPosted: 13:16 - 06 Apr 2012    Post subject: Reply with quote
just different methods used really, the grip glues and lockwire techniques are good if you want extra confidence when ragging the tits off your bike round track.
the one thing i don't like about the hairspray technique is that it has been reported that the ingress of water from washing or riding in the rain CAN turn the hairspray into a lube!
dextersaurus
PostPosted: 15:45 - 06 Apr 2012    Post subject: Reply with quote
Renthal Grip Glue.
Worked wonders on my bikes.
https://www.moorespeedracing.co.uk/user/products/large/RENTHAL-GRIP-GLUE.jpg
Sako
PostPosted: 16:07 - 06 Apr 2012    Post subject: Reply with quote
that grip glue is pretty good, i'm sure it was found that it's essentially that modelling cement/glue, so think that would work too.
Gazza M
PostPosted: 16:17 - 06 Apr 2012    Post subject: Reply with quote
cheers Smile i'm pretty sure now the throttle tube's gonna break before the araldite does!
and sako - they're r&g ones, the grips feel real nice compared to my knackered old ones!
Sako
PostPosted: 16:22 - 06 Apr 2012    Post subject: Reply with quote
i dare say you're right!
don't see them moving in a hurry after being fitted with araldite! Laughing
Cunnington
PostPosted: 16:31 - 06 Apr 2012    Post subject: Reply with quote
I use double sided sellotape, wet it with petrol and simply slide the grips on.
It's how they (used to?) do golf club grips, costs a fraction of the special adhesives and does not shift - I've had to cut grips off that have been done this way.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
binge
Emo Kiddy
PostPosted: 18:08 - 06 Apr 2012    Post subject: Reply with quote
This! ^
I use clear lacquer to apply all of my grips.
Just spray a bit down inside the grip, then apply it to the bars by twisting it on, until it's where you want it.
Then leave to set. They set solid, and dont slip in the rain or anything!
AND, when you come to remove them, just stick a screwdriver down the end of the grip, and spray a bit of brake cleaner or thinners down there, and it'll slide straight back off again.
Ben
kiddakidda
PostPosted: 19:54 - 06 Apr 2012    Post subject: Reply with quote
Gorilla Glue.....
But don't use too much as it expands.
Easter Bunny
PostPosted: 20:05 - 06 Apr 2012    Post subject: Reply with quote
I as advised by a very knowledgeable person to "attach" the heated grips using....................fairy liquid!!!!
and it works, lubricates to get the grip on and once dry creates a sticky seal which hasnt moved once and very easy to break by sliding a screw driver around when the grip thins out & needs replacing, which allows you to reuse the throttle tube.
I had to chip the last grips off bit by bit dunno what they used! Shocked
The last post was made 13 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 80.37 Kb
