Torque talk
Okeydokey
PostPosted: 02:00 - 08 Apr 2012    Post subject: Torque talk Reply with quote
Any one recommend a decent make/brand of torque wrench for me CX500? I'm buying tools as I need them, (can afford them) and I gather even putting plugs in would benefit from one, might even move to getting me self a socket set at some point Rolling Eyes
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it in a fruitsalad!
YB100 v. Ford Sierra (1982 I came 2nd place) Honda H100S (Currently 0 - 0) CX500 Cafe project (me 1 - wife 0.... maybe!)
Teflon-Mike
tl;dr
PostPosted: 03:09 - 08 Apr 2012    Post subject: Reply with quote
You shouldn't need a torque wrench to put spark plugs in!
Not MUCH point in having a torque wrench, unless you have sockets to stick on the end of it.
Torque wrench really only any use if it measures.... NOTE 'MEASURES' the necessary torque range.
Its a measuring implement for setting the final tightness of a fastner NOT a fancy ratchet!
You'll generally need a high-range torque wrench for stuff that has to be done up effoff tight without shearing the bolts, like brake caliper bolts or cylinder head nuts.
You'll more often need a LOW range torque wrench, working on motorbike engines to avoid stripping threads from fine pitch holes in aluminium cases.
End of the day, most manuals will specify a torque setting withing reletively wide limits.
MORE IMPORTANT than accuracy is 'reliability'..... if book says you have a torque setting of 16-20ft-lb, you don't need a wrench accurate to 0.1ft-lb... it doesn't matter.... as long as you are within 1-2ft-lb of the limits.
What's important is getting ALL the fastenings on a flange the SAME setting, as close as possible.
So, you dont HAVE to have the 'best' torque wrench; even a cheap chitty one will usually be accurate 'enough', IF you use it right.
So when you tighten a set of studs; say a primary drive cover... you put the bolts in and do them up finger tight, then you give them a 'nip' preferably with a spanner, but if you have to with a socket and STANDARD wratchet.
THEN you 'set' the torque with your torque wrench. Which as a contientiouse mechanic you will find in its box 'zeroed' on the scale so that the spring latch that clicks at torque setting isn't weakened by in stoirage being left under tension. Wink
Then you set about HALF the book torque setting...... and you MAKE FUCKING SURE you read the book properly and are SURE you are setting the right UNITS...
Commonly quoted are ft-lb (Foot-Pounds-Force); Kg-m or Kgf-m (Kilogram-force-meters) or Nm (NewtonMeters, the SI unit of torque)
a Kilogram Force is the force of one kilogram under acceleration due to gravity.... its nearly ten times as big as a Newton Meter.
A pound is just under half a Kilogram, and a foot just about a third of a meter, so a ft-lb is roughly half way between a Kg-m & a Nm.
Ie read the wrong scale and your nuts will be too loose, or you'll shear them!
And I've watched FAR too many times; enthusiastic ameteur mechanic grabs the Haynes manual, wants to be 'diligent' so finds the torque wrench settings for the M5 oil pump screws he's tightening up; sees a number like 16 'somethings' that might as well be greek to him... grabs the bog off big torque wrench for setting cylinder head studs, cant find 16 on the scale, so sets 160, then "OOOPS" as tiny little screw SHEARS under VERY big strain!
So, having double checked both the units in the book, and the units on the wrench; looked at the size of the fastener, and the size of the wrench and applied QUICK bit of cocum.... "Little screw; do I need BIG wrench?"
You set HALF the book torque setting, and LOCK the setting on the wrench with the lock screw.
This means you cant accidentally change teh setting half way through doing up a fastener...
And you tighten ALL of the screws on your flange to THAT setting, WITHOUT changing it.
Now, you undo the lock screw, and wind the setting up to 3/4 of the specced torque; lock the scale again, and repeat, taking ALL the fasteners in the flange up to the new setting.
Then you unlock, and wind up to the LOWEST number of the book's 'range' of torque settings, lock, and again work round ALL the fasteners, giving that 'almost' final tighten.
LASTLY, you set the mid point of the book torque and give all the fasteners in the joint a final 'check' setting.
THAT way, you get them all tightened to within the specified tolerence, but more importantly, within a nice close tolerence of each other, which is normally the more important.
THEN you unlock the scale setting screw, wind it back to zero, give the wrench a wipe with an oily rag, and put it back in the box.
Used like THAT, you dont 'need' a really good or expensive wrench.
I have had a 'cheap' £10 Torque wrench I got at a motorfactors closing down sale almost twenty five years ago, last and do the job , often and repeatably for over fifteen years, until I was given a fancy expensive one by a magazine; and when I checked the calibration on the old one, it was within 2ft-lb of the expensive one, despite much abuse!
As for where to get one; I always seem to end up at machine mart. Cheaper than Halfords for similar quality, and I get served by some-one old enough to shave, who doesn't answer any question with "sorry, I only know about the bicycles"
Also about the only place I have found a low range torque wrench for under £80 in recent years; think it was £25 or something daft, last year, when I realised I had always had the borrow of one!
But as said; if you dont have sockets to stick on the end; as yet rather like buying a plough before you got a tractor to drag it!
cb1rocket
PostPosted: 21:28 - 08 Apr 2012    Post subject: Reply with quote
Mike, that post was erm over the top, but I agree with you.
A torque wrench is over the top for most things on regular service for motorbikes.
How many time have I hear people stripping oil sump bolts using a torque wrench, EVEN some of the figures quoted from the manual for torquing things up are beyond a joke!
I personally did something up and whoosh, oh dear stripped treads. Everything I do, pretty much comes down to feel.
flumpy7
PostPosted: 21:47 - 08 Apr 2012    Post subject: Reply with quote
I dont own a torque wrench, never have. I do all jobs myself except for tyres and never had any probs. Save yourself a few quids and just tighten till it feels right.
PS i cant be held accountable if you dont do your wheel axle nuts up tight enough and your wheel falls out lol
2012 Sinnis apache
PostPosted: 22:22 - 08 Apr 2012    Post subject: Reply with quote
https://www.parktool.com/uploads/images/blog/repair_help/tw5.jpg
Deflecting beam torque wrench. Use it to tune your mechanical sympathy, not as a substitute for it.
Timmeh
PostPosted: 22:29 - 08 Apr 2012    Post subject: Reply with quote
I've only tend to use a torque wrench on cylinder heads bolts and things that move inside the engine, where its the same amount of torque on the bolts rather than the actual value itself which matters most.
The rest of the bike I put together by feel alone. Using the right tool for the job and stopping when I can't move the spanner with one finger seems to work for me.
As others have said, the torque settings you read aren't always correct, and I can attest to some fairly expensive and time consuming mistakes by improper use of torqies.
Penny CoinPenny Coin
There is a gap of 1 year, 264 days between these two posts...
Yosh
PostPosted: 21:42 - 29 Dec 2013    Post subject: Reply with quote
I'm still learning how to maintain my YBR and my next big job is going to be replacing chain and sprockets. I would like to get a wrench that would suit this job.
I've had a look at the Machine Mart page and their prices seem fair and their tools are usually good enough quality. Can someone tell me what size wrench might be suitable for this job, also if I wanted to use a torque wrench on a range of jobs on the bike, might I need to buy a small and a large one?
Any advice would be appreciated.
The other Paul Rudd This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
cb1rocket
PostPosted: 01:37 - 30 Dec 2013    Post subject: Reply with quote
Sounds fine, but just don't use a torque wench to undo things
Copycat73
PostPosted: 11:39 - 30 Dec 2013    Post subject: Reply with quote
I have one of these they are ok not the best quality ever made but will do 6mm to 10mm nuts & bolts.
https://www.amazon.co.uk/Draper-28757-8-inch-10-Ratchet/dp/B009VYBFBO/ref=sr_1_2?ie=UTF8&qid=1388399739&sr=8-2&keywords=torque+wrench
caveat emptor
Copycat73
PostPosted: 11:41 - 30 Dec 2013    Post subject: Reply with quote
caveat emptor
PostPosted: 11:57 - 30 Dec 2013    Post subject: Reply with quote
Don't touch that with a badge pole, I had one and it broke after 3 uses.
The mechanism that clicks when the torque is hit broke, meaning the wrench wouldn't tell you when to stop turning.
The other Paul Rudd
PostPosted: 12:04 - 30 Dec 2013    Post subject: Reply with quote
This subject comes up every few weeks and reaches the same conclusion. So rather than dragging up two year old threads why doesn't a moderator create a sticky where people can post about their tools and review them, like the workshop guides thread.
PostPosted: 12:17 - 30 Dec 2013    Post subject: Reply with quote
Cos that would be a waste as no one reads stickies. Laughing
Could however get a sticky of what not to shout at someone when they do their first post, with "You're a fucking twat" coming in at number 1 Laughing
The other Paul Rudd
PostPosted: 13:35 - 30 Dec 2013    Post subject: Reply with quote
We could have one about how to use the search function properly as if it's used correctly you can find all of Tef's posts, which will keep anyone occupied for a while, and he does make sense in some of them.
Copycat73
PostPosted: 14:23 - 30 Dec 2013    Post subject: Reply with quote
that is unfortunate, would seem that the one supplied was defective,
mine however was not and still is not and has been used considerably more than 3 times. Thinking
caveat emptor
MartQ
PostPosted: 18:47 - 30 Dec 2013    Post subject: Reply with quote
My torque wrenches are 44 years old and been in daily use for those 44 years. They have a 5 step main setting with infinite adjustment in between each of those settings:
1 white knuckle, 2 white knuckles......5 white knuckles.
Clutch nuts are 5 white knuckles, cylinder head nuts are 3 white knuckles etc ... Laughing
Chalky.
PostPosted: 19:32 - 30 Dec 2013    Post subject: Reply with quote
What, like searching for "torque wrench", finding this thread, and posting in it rather than starting a new one.
Then some stupid cunt calls him a twat...
The other Paul Rudd
PostPosted: 19:44 - 30 Dec 2013    Post subject: Reply with quote
Or sorting stuff by date, finding one from the past week and posting in that so some cunt doesn't call him a twat.
And had he found said thread he'd have found that Mike actually answered his question perfectly.
PostPosted: 19:56 - 30 Dec 2013    Post subject: Reply with quote
You think he would be able to pick out the relevant points of a Teflon-Autism post?
The other Paul Rudd
PostPosted: 20:02 - 30 Dec 2013    Post subject: Reply with quote
Awwwwwww leave him alone you big bully you. I quite like him as at least he tries to help, and his heart is in the right place, even if he does go a little ott. Laughing
Chalky.
Why does it matter if the thread he bumps is 2 weeks old or 2 years old? They will both be there. At least he used the search function.
I don't understand why you felt the need to be such a cunt.
Mike doesn't answer questions, he posts inane shit that no one can be arsed to read.
Clutchy
PostPosted: 20:16 - 30 Dec 2013    Post subject: Reply with quote
I'm one to rage when someone posts the same topic over and over again such as the new licensing laws, but this guy actually used the search function.
WELL DONE Clapping Smile
Yosh
PostPosted: 13:01 - 01 Jan 2014    Post subject: Reply with quote
Thanks for all the help guys, even you Paul, you grumpy sod Smile
The last post was made 12 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.32 - MySQL Queries: 16 - Page Size: 137.05 Kb
