| spitfire123 |
 spitfire123 Could Be A Chat Bot
 Posted: 04:16 - 09 Apr 2012 Post subject: spark plug snapped in head! |
hi all,
doing a full rebuild on a 95 ninja 600. shes in a bad way to be fair needs alot of work.
Right.. the spark plug holes were all corroded up but cleaned all out.. managed to get 3 plugs out fine and on the last one its boody snapped!!
the engine ran as sweet as a nut before anr REALY don want to ake the head off.....
is there any way of removing it not taking the head off.
cheers ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 04:28 - 09 Apr 2012 Post subject: |
Is there any way to get a deep socket over the remainder of the plug?? or has the hex part of the plug come out already??
[edit] or maybe even use something like a bolt extractor... very carefully
https://www.matcotools.com/ProductImages/mbx5.jpg
I'm sure there's other members with more info, or pro experience ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| spitfire123 |
 Posted: 04:48 - 09 Apr 2012 Post subject: |
hi mate,
there is no bolt left just the thread burried in the head.
i will get a pic when my phone charges. but it is litraly the thread in there with some white porcoline showing thats it.
and bearing in mine its 2-3" in the head it makes it even harder to get at!
thanks for your help.
apriciated  ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| Pete. |
 Pete. Super Spammer
 Posted: 07:25 - 09 Apr 2012 Post subject: |
Not removing the head is a bit of a non-option here. If you drop even the tiniest piece of that ceramic insulator into the engine it'll tear the piston up.
Head off time I'm afraid. ____________________ a.k.a 'Geri'
| Budgetboy |
 Budgetboy Scooby Slapper
 Posted: 08:51 - 09 Apr 2012 Post subject: |
Head off mate im afraid.
if i had it here i would use heat on the stubborn plug.The heat will expand the metal (alloy v normal metal)
It takes allot of patience to remove these and if you get it wrong you will ruin the threads in the plug port.So don't go wacking it out.i would then weld a bolt on the underside (once the innards was out) then heat it up, ass some lube and slowly apply pressure. 9/10 it will come out.
2nd hand Cylinder head is about £60-£80 just so you know. ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| kestrel |
 kestrel Nearly there...
| Bezzer |
 Bezzer World Chat Champion
| RIDINGforKICK... |
 RIDINGforKICK... Scooby Slapper
| Pete. |
 Pete. Super Spammer
| RIDINGforKICK... |
| swampy |
 swampy World Chat Champion
| RIDINGforKICK... |
 Posted: 13:38 - 09 Apr 2012 Post subject: |
https://www.xs650.com/forum/showthread.php?t=13252
It's an old trick, and well known it the trade.
It really depends on what you have to hand when the situation arises.
Just about any thing tool steel hard and square and about the right size can be hammered in, but you need a way of turning it. |
| spitfire123 |
| RIDINGforKICK... |
 Posted: 14:31 - 09 Apr 2012 Post subject: |
| Pete. |
 Pete. Super Spammer
| Budgetboy |
 Posted: 14:50 - 09 Apr 2012 Post subject: |
If the screw extractor snaps (which the sometimes do) you are in a world of s***.
Take the head off and do it properly.
if you were closer you could have dropped your bike off at mine and i would have done all the calipers,carbs and other stuff for you.It would cost you less and be quicker lol. ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| RIDINGforKICK... |
| Mikey3 |
 Mikey3 World Chat Champion
 Posted: 17:28 - 09 Apr 2012 Post subject: |
providing its snapped flush, could you put a nut over it and put some weld inside the nut, so it only welds to the plug, Then get a long reach socket, or a spark plug socket which is the same size as the nut, obviously, to get it out?
Might need someone with some skill though, I doubt its as simple as steel to steel, not sure how this technique would work with a spark plug, but im sure someone will
Mike ____________________ '04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it' |
| Pete. |
 Pete. Super Spammer
 Posted: 17:37 - 09 Apr 2012 Post subject: |
You won't get near it, the stuck part is three inches down a narrow hole. ____________________ a.k.a 'Geri'
| Budgetboy |
 Posted: 17:43 - 09 Apr 2012 Post subject: |
yep you wont be doing that with the head on the bike. Its about 6-7 inches down a inch and a bit hole.
As we said Head off the bike..No easy way around it.. ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| spitfire123 |
| Budgetboy |
 Posted: 17:56 - 09 Apr 2012 Post subject: |
Its £20 for a head gasket for your bike mate. Another engine is probably £200 odd. And even then you dont know what you are getting. ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| spitfire123 |
| Budgetboy |
 Posted: 18:12 - 09 Apr 2012 Post subject: |
It wouldnt be,
You would set the timing before you take the head off.That way when you put it all back together it will already be done.
And you would use the same head bolts.
Just buy a new rocker gasket and new head gasket. Torque the head down to spec and you will be fine. ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
The last post was made 13 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
