Aluminium body panels?
PostPosted: 20:05 - 09 Apr 2012    Post subject: Aluminium body panels? Reply with quote
I'm thinking of doing some filler side panels for my new GPZ 500, in between the top fairing and the belly pan. Like chuff am I paying ~£80 for plastic ones, so I was pondering just knocking something up out of aluminium.
In a previous life I made a kit car bonnet out of aluminium, but that was quite some time ago, so I'd welcome suggestions for an appropriate thickness to use. There's just a gentle, simple bend to go in it, plus I'll likely fold it over at the edges and make it good with filler. So, 2mm? More? Less? Should I use something else instead? Any reason I shouldn't do it? Won't go with the twisted subframe?
https://i42.tinypic.com/6rpkbr.jpg
Ariel Badger
PostPosted: 22:03 - 09 Apr 2012    Post subject: Reply with quote
2mm sounds about right, you know how to anneal ali? You rub it in hand soap and heat until the soap blackens.. any hotter and it will melt.
PostPosted: 22:10 - 09 Apr 2012    Post subject: Reply with quote
14 or 16 gauge seems suitable. You'll need etch primer to get paint to stick to it.
Nexus Icon
PostPosted: 23:42 - 09 Apr 2012    Post subject: Reply with quote
You might think £80 is a lot of money but how high do you value your own hourly rate? It's going to take you hours to do a half decent job and it would probably still look better with the right parts.
Seriously, buy the plastics and spend the hours saved enjoying the bike, not hitting your thumb with a hammer.
Greetings from Shitsville!
PostPosted: 00:22 - 10 Apr 2012    Post subject: Reply with quote
Eh, fettling isn't my day job. I likes me a bit of bodging time in the shed.
14 - 16 gauge is 1.5mm. That, or 2mm?
Good call on the acid etch, I'd forgotten about that particular bit of fussing around. Thumbs Up
PostPosted: 00:28 - 10 Apr 2012    Post subject: Reply with quote
16 gauge is easy to remember - 1.6mm or so
https://mdmetric.com/tech/steelthk.htm
Ariel Badger
PostPosted: 00:37 - 10 Apr 2012    Post subject: Reply with quote
Also 1/16 of an inch Very Happy
Nexus Icon
PostPosted: 13:38 - 10 Apr 2012    Post subject: Reply with quote
I meant the hypothetical value of your spare time, tbh.
Robby
Dirty Old Man
PostPosted: 14:57 - 10 Apr 2012    Post subject: Reply with quote
Just get some used ones off ebay, or fix up what you have.
Ali will be a bastard to shape, then will probably rattle a lot. It'll also look balls.
DrDonnyBrago
PostPosted: 16:52 - 10 Apr 2012    Post subject: Reply with quote
Presumably it functions fine without the panels so why bother?
I am sure there are other parts of the bike that could benefit from the time and attention more and if you are just worried about the cosmetics, eat less pies, lose the hi vis and sellotape a paper dragon to your helmet.
Ichy
PostPosted: 16:59 - 10 Apr 2012    Post subject: Reply with quote
Is it one of these on ebay ?
If so then it is a fairly complex shape to form. You will need to weld the flanges to get the depth of some of the edges correct.
PostPosted: 17:05 - 10 Apr 2012    Post subject: Reply with quote
Put some braided lines on it first. Thumbs Up
PostPosted: 21:24 - 10 Apr 2012    Post subject: Reply with quote
I've updated the image at the start of the thread to highlight the area.
Why? 'Cause.
There's none to be had used.
If they look balls, I'll bin them.
PostPosted: 21:27 - 10 Apr 2012    Post subject: Reply with quote
You could get at least 4 or 5 neons in that gap.
The last post was made 14 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 87.03 Kb
