| butcher750 |
 butcher750 L Plate Warrior
 Posted: 21:05 - 10 Apr 2012 Post subject: idling problems on my suzuki gsx750 |
Hi guys!
I am new to this forum, and not very good with computers, but my son is helping me out!
I have a 1985 Suzuki GSX750EF (I think, could be E or ES)
I am having problems with the idling, because it just won't tick over, even when up to temp. with the choke off. As soon as I let go of throttle, she cuts out.
Is it simply a matter of adjusting the tickover adjusting screw on the throttle valve screw on the carbs, or is it something deeper than that? If it is just the throttle valve screw, is this a simple matter or is it something that would invovle stripping the bike down ie taking the tank off, or even worse removing carbs all together?
Do any of you guys out there know the answer or can point me in the right direction??  |
| Budgetboy |
 Budgetboy Scooby Slapper
 Posted: 21:20 - 10 Apr 2012 Post subject: |
idle jet blocked on your carb mate.remove carb and clean.
 ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| temeluchus |
| Ariel Badger |
 Ariel Badger Super Spammer
| Casper |
 Casper World Chat Champion
| fireyphoenix1... |
 fireyphoenix1... Brolly Dolly
| fireyphoenix1... |
| temeluchus |
| butcher750 |
 Posted: 23:17 - 11 Apr 2012 Post subject: |
Hey Guys,
Thank you all so much for your advice, thats given me quite a bit to be getting on with...- I'm going to trouble-shoot using your advice, see what is going on, and then I'll update you all with my findings, and when she is up and running again properly!
I find the water test on the exhaust down-pipes very interesting, and I shall try this, however, when up to temparature, she is singing on all four, and goes like a rocket with no miss-fire, and also no flat points. Engine cuts out as soon as I stop if I don't keep blipping on the throttle.
If, as I suspect, all I need to do is adjust the idling screw, how the hell do I get at it??!! - Has anybody got any advice on this or any pictorial diagrams??!
Many thanks to you all once again, will keep you all up to date!
Gaz from lowestoft |
| fireyphoenix1... |
 Posted: 23:35 - 11 Apr 2012 Post subject: |
first things first check the idle it could simply be that the adjuster is turned too far out
you haven't stated if you have had the bike a long time or what so im going to assume that the idle screw is either too far out or missing as in the case of my bike when i got it lol
im not sure what type you have so i will post both the ones i know of
https://img199.imageshack.us/img199/2852/dsci0060r.jpg
on ^these^ idle is the large brass screw in the middle between carb 2&3
https://www.factorypro.com/images/carb_shots/carbfs_36mm_Mikuni.jpg
this large (brass ?)^^^^ adjuster on the left with a cable going to the middle of carbs 2&3 is the idle speed screw the four with red arrows are the mixture screws
hope this helps mate
as for the water test keep high enough RPM to keep it running then slowly close the throttle.
As it moves back on to the pilot circuit the bike should start dropping a cylinder if there is any blockage in carbs this will show you which ones is blocked .
a carb strip and rebuild isnt as bad as people make out i can do it in 20mins now after having done it about 10 times ____________________ 2014 Aprillia dorsoduro 750 factory. |
The last post was made 14 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
