Simple spark plug help!
karthead
PostPosted: 09:25 - 11 Apr 2012    Post subject: Simple spark plug help! Reply with quote
Hi all,
Just recently bought a Kawasaki KE125 to fix up. The ignition coil was damaged so i tried to find a replacement, however, the only available ignition coil was from a KE175. Would this produce more spark? Could this possibly be damaging to the spark plug and burn it out quickly? Will it work?
Thanks for all your help Smile
PostPosted: 09:30 - 11 Apr 2012    Post subject: Reply with quote
It wont be damaging the sparkplug. I would say as long as it's off a bike with the same voltage, you should be fine.
Is it points ignition or CDi?
If it's points and you're burning out sparkplugs, check the gap and consider replacing the condenser.
karthead
PostPosted: 09:34 - 11 Apr 2012    Post subject: Reply with quote
It is point ignition, but from where i've read, the KE175 is CDI ignition. Would this matter? Would it also matter if the bikes are different voltage? Im not very familiar with the ignition system as you can probably tell Laughing
The last post was made 14 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.98 - MySQL Queries: 13 - Page Size: 35.28 Kb
