Bikes with Good MPG?
Ted
PostPosted: 13:57 - 11 Apr 2012    Post subject: Bikes with Good MPG? Reply with quote
Hi all, my two CX's are staying off the road for a bit longer, and I'm thinking of getting another cheap run-a-round bike.
I thought of a 125cc as they are cracking on fuel, but the initial cost of the bike is steep for obvious reasons!
So, I was thinking about something between 125cc and 250cc, preferably a commuter or cruiser, not interested in sports or dirt bikes.
I'm only after spending a couple of hundred max buying it, but was wondering what bikes anyone recommends, and what the MPG is going to be like?
PostPosted: 14:08 - 11 Apr 2012    Post subject: Reply with quote
Few hundred will get you a CB250, looks around 70+ mpg
garth
PostPosted: 15:43 - 11 Apr 2012    Post subject: Reply with quote
C90, 120MPG.
I can get half that out of my zx9r at a constant 70mph. Shortly followed by boredom induced death.
PostPosted: 15:46 - 11 Apr 2012    Post subject: Reply with quote
garth wrote:
C90, 120MPG.
But they are horrible to ride unless you are playing at trying to wheelie them Laughing
I'd rather have a twist and go for a short commute than a C90.
Triumph Trophy Launch Edition
.Chris.
PostPosted: 16:22 - 11 Apr 2012    Post subject: Reply with quote
Suzuki GN250/400, Yamaha SR250, Honda CD200. You might get a tatty RXS/GP/H100 for that sort of money, or a CB100N.
TBH if your budget is only £200 or so, you can't afford to be too picky!
Chris
1985 Kawasaki Z550F
Teflon-Mike
tl;dr
PostPosted: 16:34 - 11 Apr 2012    Post subject: Reply with quote
Well the CX500 isn't exactly renowned for being thirsty... and I can get better mpg from my CB750, if I ride it like a CG....
And that is the real key to ecconomy.
POWER=Rate of Energy Transfer.
Ie MPG is actually an expression of 'power', only how much you use, rather than how much the engine might make at a certain rpm & throttle setting.....
Power also = Force x speed
Force in question is 'drag', speed, how fast you are going.
Drag increases with speed, so faster you go, more fuel you are going to use.
Drag, on a motorbike, is much of a much. People talk about aerodynamics, but TBH aerodynamic efficiency on a motorbike makes bog all odds.
Yes faired bikes are more erodynamically efficient, but up to about 120mph, real advantage of faired bikes tends to be the smaller frontal area rather than streamlining.
SO, pretty much any bike, ridden for ecconomy; as smoothly as possible, avoiding hard acceleration or braking, riding predictively to hold a high average speed.... up to 'about' 50-60mph, power, hence fuel used will be pretty similar.
So, since you HAVE a CX500 and armed with such knowledge, I would ask WHY you want to chuck a sum of money that will struggle to get you a 'fixer-upper' at something that probably wont do the job you want ANY better than what you got?
Would it not be a better idea to chuck that dosh at getting one of the CX's to road?
Otherwise; probably THE most miserly, economy-commuter currently known to man, is teh Honda CD200 Benley....
15bhp its just about as powerful as a half decent 125, but with 60% more displacement, has a bit more 'beef; where you can use it, and its optimum efficiency is stacked a bit higher up so you can hold better ecconomy on 50-60mph roads where you'd be ragging a 125 to hold road speed.
Also in a hole in the Insurance groupings; where it wont gain Learner-Loading, and where there aren't any sports bikes hiking premiums from cracked fairings, of high speed lunacy.
And you CAN find examples, Taxed and MOT's for £200 ish if you hunt hard, but they will sure be FAR from 'pretty'.... and to my sense of sensibilities and experience of the breed, since top book, a minter will struggle to fetch much over £500, youi might as well buy high, and have a bike that stands better chance of being mechanically sound and reliable, rather than one likely to be a money pit... no-one spends big money on a 'cheap' bike, so better ones can be a real bargain.
Derivative
PostPosted: 17:14 - 11 Apr 2012    Post subject: Reply with quote
Fuel really is cheap compared to the cost of the bike and associated bits unless we're talking years of long mileage journeys.
A 20 mile commute 5 days a week for a year is roughly 10k miles.
At £1.40 a litre, an imperial gallon is £6.35.
At 50mpg, (10000/50)*6.35 = £1270 annually for fuel
At 75mpg, (10000/75)*6.35 = £846
At 100mpg, (10000/100)*6.35 = £635
Look at the difference between 50 and 75.
You are likely going to be looking at about £4-500 cost savings per year on 10,000 miles, is that worth the added insurance, maintenance, space in your garage/garden and the rest of it?
May be useful in winter, but otherwise I think two bikes is false economy to be honest. I hear even Pan Euros get about 40mpg.
Either go for a 125 that'll do 100mpg, or go for broke IMO. Inbetween, you'll get hardly any fuel economy improvement, and be riding something you don't actually enjoy.
Mikey3
PostPosted: 17:15 - 11 Apr 2012    Post subject: Reply with quote
you won't want a Hornet pre 2004 Laughing
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Ted
PostPosted: 17:17 - 11 Apr 2012    Post subject: Reply with quote
Thanks for the feedback guys.
Just to clarify, I'm expecting a really tatty and run down bike, so I'm not likely to get any shocks there!
I understand economical riding is the key, but I was getting about 90mpg out of my old 125cc, compared to about 45mpg out of a CX500... Considering my car does 50+mpg it's actually cheaper using that instead of a bike.
Both the CX's are currently off the road, and one would need a hell of a lot of work/money to get on the road again, the other isn't as bad, but I can't warrant pouring money in for an mpg that's worse than the car!
The only reason I'm put off of bikes that are 125cc and under is because they often carry a higher price tag, you can get more for the money with something just over learner size.
I'm working on the assumption that a 250cc will better a 500cc on mpg (with similar riding), but I know this isn't entirely the case as under-powered bikes can use more fuel, but I also have to factor in insurance costs, as I've not got any NCB to use and I've not been riding a 500cc+ bike regularly for the last year or so!
Derivative
PostPosted: 17:25 - 11 Apr 2012    Post subject: Reply with quote
I know that the Ninja 250 gets about 70mpg if you ride reasonably, and my CG125 got about 100-110. Not too sure about touring/street 250's.
If a 125 will be enough I'd say definitely get one.
A 250 is unlikely to save enough fuel to be worth bothering with unless you get one really, really cheap. A £1k bike would take about 25-30,000 miles to break even against the car (at 50mpg vs 70mpg)
If you get a CG for under a grand it'd make up for itself in a year or two.
I suppose it depends how much monetary value you put on riding compared to taking the car.
Teflon-Mike
tl;dr
PostPosted: 17:39 - 11 Apr 2012    Post subject: Reply with quote
45mpg from your CX suggests that its pretty 'shagged', it ought to be returning more like 70, if you ride it sensibly.
Buying a shagged out 125 or 250, is going to put you in EXACTLY the same boat you are in with the CX of poverty mechanics, and the spiral of NOT spending money to make it right, because its already costing too much.
As said, you CAN get old CD200's for a couple of hundred quid. And teh CD200 CAN return 70-90mpg, if ridden for ecconomy. But one that's got worn bores and is supping oil through the valve stem seals wont..... and a £200 bike thats costing more than it ought to to NOT do the job, is NOT going to get a £150 top end rebuild to put it right in a hurry, on the exact same logic as what you are already applying "Cheaper to buy another one!"
So you'll have two clapped out CX's, one clapped out CD, and rather than fix any of them, or cut your losses, you'll end up with a £100 Suduki CG-Clone that is only three years old, but just failed its MOT, a 'good little runner... but.....' and THAT wont get the attension it deserves to get it up to scratch and through the MOT, because a £30 regulator to even start de-bugging the electrical gremlins it has will be deemed 'too expensive'.
You KNOW the score, you KNOW what we are dealing with, and its the desperation of poverty, and the optimism of enthusiasm over realism.
If the car is cheaper to get to work, and thats all that you want to do... use the car! Sods bikes.
If you want the bike, get your arse in gear, and if you dont reckon the maggot is worth making good, DITCH IT!
Bung the pair of them on e-bay as 'Project' bikes and let some other mug have the hassle with them.
Judging by project bike prices, two CX's ought to bring in, maybe £400 between them, maybe more, especially if you parted them out rather then trying to sell whole...
But that, the £200 you would chuck at yet another desperation deal, would give you maybe £600... not a great deal to play with, but there are useful bikes out there at that kind of money that could do the job.
Top that up with what you WONT spend on making a CX 'good', maybe £1000-£1200, and you are bang on, and ought to be able to pick something VERY useful to do the job you want; you are into SV650 territory if you want something more inspiring, but certainly in the realms of CB500's, that would return the sort of mpg you hope for.
Or IF the CX is REALLY what you really want to be riding... bite the bullet, chuck the money at that, make it do ethe job intended, and eat the ecconomics.
Its cakes and eatings, mate!
Ted
PostPosted: 17:58 - 11 Apr 2012    Post subject: Reply with quote
I'm not planning on parting with the maggots, with two bikes, one spare engine, and a couple of boxes of parts (including spare carbs), I think it would cost a lot to get back to the same situation as far as spares go with another bike.
My plan was to get something cheaper to run than the car, just to commute back and forth.
Can I ask if that 70mpg for the CX is a personal estimate, or a book value?
I am watching loads of bikes on eBay, but I'll admit I'm currently swayed back towards the CX due to the number of parts I have, or just stay bike-less until I'm in a better situation...
Derivative
PostPosted: 18:41 - 11 Apr 2012    Post subject: Reply with quote
That's just the thing: if it is actually about what is economically viable, and nothing else, the car is likely to end up cheaper.
As stated earlier, a 50mpg car will cost about £3-400 more than a 70mpg bike for every 10,000 miles.
You'd have to do a hell of a lot of mileage to make a 250 worth buying.
neil.
PostPosted: 18:42 - 11 Apr 2012    Post subject: Reply with quote
CBF125 - check the Fuelly link in my sig. Thumbs Up
.Chris.
PostPosted: 18:46 - 11 Apr 2012    Post subject: Reply with quote
Not many of those about for £200 though! Laughing
Chris
1985 Kawasaki Z550F
Teflon-Mike
tl;dr
PostPosted: 19:07 - 11 Apr 2012    Post subject: Reply with quote
Personal estimate.
Mate who ran the windjammer faired Silver-Wing for years, used to get an average of around 55mpg from it, and that's the heaviest and MOST un-ecconomical of the breed.
2nd hand experience from foilk I know that have cranked up extensive CX mileages... so couriers then.... suggest that a 'good' CX that's properly serviced, carbs set up, tappets tickety boo, and on a fresh timing chain all properly timed in, can get nearly 80 to the gallon....
Its ONLY a 50bhp twin cylinder machine, these figures are not unachieveable.
As said, I have had 70+ from my CB750, which has a much more highly tuned DOHC a 75bhp four-pot motor.
Book specs I have spotted suggest around the 50mpg mark, but those will be average, and that's what it says my CB750, that ought be no where near as ecconomical ought to return!
And you are missing the point; Cash in the 'SCRAP' you currently have in the garage NOT doing anything for you, that needs more money still chucking at it to make a serviceable motorcycle... and buy a CB500 commuter twin, that does the job 'out the box' you ought not NEED to have any ruddy spares lying around!
Say it out loud:
I have two bikes and LOADs of 'spares', niether work... it'll take me YEARS to buy another bike and get to the point I am now.....
What, get to the point that the bikes worn out beyond redemption, been replaced by another and BOTH are lying amongst a pile of salveged spares, none of which will make a complete functioning motorcycle?
I think you just talked yourself into the plan, there mate! Laughing
If you REALLY have to have a CX500, then get your arse into gear, eat the ecconomics and FIX one of the little fuckers and be HAPPY.
If you JUST want a functional, useable, road legal motorbike; get the fuck RID on e-bay, scrape the pennies into a pile, and go BUY something that DOES THE JOB!
You are in a hole, so deep, and so slippery with EP90 from the shaft drive, you cant even ruddy see it!
iooi
PostPosted: 19:19 - 11 Apr 2012    Post subject: Reply with quote
10K on a bike is going to mean a pair of tyres at least 2 services on a old bike. Never mind the other consumables.
The same for a car is next to nothing. Given that a 50mpg car is not going to be a fast expensive car.
Tyres 30K, brakes about the same. Service is maybe once, or if like mine every 20K.
My car works out cheaper to run than my bike on the commute to work.
And my car only does 40 mpg compared to 60 mpg on the bike.
Untill you factor in the time diffrence. Going its around the same. But comming home it can be upto 90 mins more in the car.
OP forget a 250 I got better MPG out of a XJ 600 than I did on a GN 250.
Derivative
PostPosted: 19:27 - 11 Apr 2012    Post subject: Reply with quote
Oh, definitely. That was going off just the fuel.
My point is that it's really not going to be cheaper, and that the fuel is not really a big factor. The difference between 50mpg and 70mpg is sod all, it's 125 or nothing.
kawakid
PostPosted: 19:52 - 11 Apr 2012    Post subject: Reply with quote
Both my bikes do about 62mpg on a ride out.
Not so good when commuting, but my commute is only 4 or 5 miles.
I've a twin and a 4.
Acemastr
PostPosted: 20:05 - 11 Apr 2012    Post subject: Reply with quote
Get anything, I get 40mpg whether I thrash the crap out of it and 45-50 if i pootle, it's about how you ride it.
Although if it's crap and slow you won't ride it like you stole it Very Happy
2016 Toyota Tacoma Limited
colin1
Captain Safety
PostPosted: 20:22 - 11 Apr 2012    Post subject: Reply with quote
mpg depends on traffic and speed.
At 60mph or above, a 900cc bike may note be more thirsty than a 600, but at 20mph, it will be.
In theory a car may have similar mpg to a bike, but will the car be stuck in traffic burning petrol going nowhere ?
I think 250 is a good economy sized engine with enough power for most situations, however it's often nice to have a bit more power than just what is needed.
SouthWestSinn...
PostPosted: 17:14 - 12 Apr 2012    Post subject: a Reply with quote
The best bikes for MPG is a moped
yh buddy!
PostPosted: 17:37 - 12 Apr 2012    Post subject: Re: Bikes with Good MPG? Reply with quote
If you check on Fuelly, an XV250 has an average of 96mpg :-
https://www.fuelly.com/motorcycle/yamaha/virago%20250
But with a budget of a couple of hundred quid, you're pretty much up shit creek sans paddle.
temeluchus
PostPosted: 18:01 - 12 Apr 2012    Post subject: Reply with quote
The k75 manages 50mpg urban commute, 60-70mpg on a speed limit pootle down the motorway.
pendulum
PostPosted: 18:41 - 12 Apr 2012    Post subject: Reply with quote
My CG 125 is excellent on fuel, I bought it for £470, it only cost £109 to insure (for a newbie 26y/o on a provisional) and everything works; I'd sell the bikes you have and use the money on a half decent CG125 and that should do you as an economical commuter until you build a bit more savings?
The last post was made 14 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 140.45 Kb
