Honda CG Won't Start
BikeNewbie
PostPosted: 16:16 - 12 Apr 2012    Post subject: Honda CG Won't Start Reply with quote
Hello,
I went to take my Bike out after not using it for around a month. It started, but then cut out. The neutral light comes up but when I push the starter button it just makes a clicking noise.
I have charged the battery but is still just clicking?
Would anyone know how to solve this problem?
Thanks.
Alpha-9
PostPosted: 16:22 - 12 Apr 2012    Post subject: Re: Honda CG Won't Start Reply with quote
BikeNewbie wrote:
Hello,
Thanks.
Tried the kick start? Thinking
Fzr-600 1999
BikeNewbie
PostPosted: 16:24 - 12 Apr 2012    Post subject: Reply with quote
It only has an Electric Start.
CaNsA
PostPosted: 16:25 - 12 Apr 2012    Post subject: Reply with quote
Drain the carb, clean the spark plug, try another battery.
In that order!
la_lucha
PostPosted: 16:33 - 12 Apr 2012    Post subject: Reply with quote
Have you tried bump starting it?
Failing that use the pedals Mr. Green
Feck Orf
P.
PostPosted: 16:35 - 12 Apr 2012    Post subject: Reply with quote
Charging the battery and it still clicks... jump start from a car/bump start.
Drain the float bowl and let it fill up.
Clicked over and over is sign of dead battery....
bodybagged
PostPosted: 18:24 - 12 Apr 2012    Post subject: Reply with quote
Bump start it, if that doesn't work replace the battery. If that doesn't work then i'd be looking for fueling/sparking issues. For example not running the bike has probably allowed shit in the tank/carbs to settle and your getting poor fuel flow etc..
BikeNewbie
PostPosted: 19:03 - 12 Apr 2012    Post subject: Reply with quote
I took the Bike for a ride after Bump Starting it and it run fine. Soon as I got home and turned the engine of and tried starting it again, It's clicking again.
John Silva
PostPosted: 19:26 - 12 Apr 2012    Post subject: Reply with quote
So you need a new battery then!
bikertomm
PostPosted: 19:45 - 12 Apr 2012    Post subject: Reply with quote
Fairly certain I know what the problem is, you don't need a new battery!
It's your starter motor.. Get a little bit of wood and a hammer and gently tap it, then turn ignition on and hit the button.
The brushes could be sticking so a little tap just free's them up, it's exactly what fixed mine.
Hope this helps! Thumbs Up
John Silva
PostPosted: 19:59 - 12 Apr 2012    Post subject: Reply with quote
He's just been riding the bike so that should of freed the starter motor if it was sticking I would of thought.
bikertomm
PostPosted: 21:30 - 12 Apr 2012    Post subject: Reply with quote
Nah, they still play up! Seems to be a bit hit or miss, once I've had a nice rideout it starts on the button fine, but say then you came out to the bike the next day, 'Click' Thumbs Down
I'm fairly certain this is the problem, may need a clean.
But worth getting the hammer out first before a new battery Twisted Evil
lol Thumbs Up
bikertomm
PostPosted: 21:31 - 12 Apr 2012    Post subject: Reply with quote
OP:
Is it exactly like this ?
https://www.youtube.com/watch?v=-oovP9hJT6Y
P.s the guy in that video does fart at 4 minutes odd as the comments state.. Laughing
P.
PostPosted: 22:27 - 12 Apr 2012    Post subject: Reply with quote
Put in 4th/5th gear and rock back n forth?
Take starter off and have a look, open it and clean it.
BikeNewbie
PostPosted: 23:14 - 12 Apr 2012    Post subject: Reply with quote
Yeah it's doing the same as what the Honda CG is doing in that video.
Should I follow that video and try and fix it myself? If it's an easy fix that is.
I will also try the things people have suggested as well.
Thanks.
P.
PostPosted: 00:03 - 13 Apr 2012    Post subject: Reply with quote
Thanks.
Easy fix, read thread posted by blixey with starter motor as the title.
BikeNewbie
PostPosted: 13:31 - 13 Apr 2012    Post subject: Reply with quote
There is 3 bolts to get it undone but do I need to clean it with anything once I take it off?
P.
PostPosted: 13:38 - 13 Apr 2012    Post subject: Reply with quote
Open it up, possible its loaded with dirt and shit.
If its brushes look worn, give them a quick rub with light sandpaper. If they look worn to the point of no return, need to replace them (2nd hand starter motor is probably cheaper..and I may have one...)
BikeNewbie
PostPosted: 13:48 - 13 Apr 2012    Post subject: Reply with quote
Is it an easy job?
I will have a go and reply back here in a while.
Budgetboy
PostPosted: 13:53 - 13 Apr 2012    Post subject: Reply with quote
Could also be a faulty starter soleniod. Thumbs Up
https://www.panmao.cn/upload/productimg/2f0j00BvOQZToEHHkP/CG125-CB125-Starter-Relay.jpg.jpeg
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
BikeNewbie
PostPosted: 13:56 - 13 Apr 2012    Post subject: Reply with quote
That's connected to the battery isn't it?
Budgetboy
PostPosted: 14:03 - 13 Apr 2012    Post subject: Reply with quote
It should be located near your battery yes.1 live goes to your starter motor, the other to your + side on the battery. Thats why i posted the image for you. Look for two 10mm nuts. Sometimes they will have rubber cap on them,but it will be near your battery.
If you want to see if it is your starter motor you can try to jump it. If you get two bits of wire and connect this to your starter motor terminals and then touch the other 2 ends onto your batterys (+ & -). (make sure its not in gear) You do not need ignition on either.
If the starter is ok the thing will spin. Do not keep the wires on there, just touch it on and off the battery.
if it dont spin its your starter motor, if it does spin its your starter solenoid or wires to it. Thumbs Up
P.
Uhuh, direct to the + side.
You are near Hastings right? If I'm free this weekend and you have nothing to do I can happily come have a look/you can bump and ride to Maidstone and I'll see if my spare fits.
BikeNewbie
PostPosted: 14:44 - 13 Apr 2012    Post subject: Reply with quote
Well I tried to remove the starter motor, But after removing the 3 bolts it still wasn't budging.
Is there more bolts?
Thanks Paddy, I will try and get it working, If not then I will get back to you on that one mate.
P.
PostPosted: 15:09 - 13 Apr 2012    Post subject: Reply with quote
Bolt wise, should be able to wiggle it...perhaps a light tapping with the bottom of a screwdriver will aid it.
The last post was made 12 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.29 - MySQL Queries: 15 - Page Size: 124.9 Kb
