sv650 electrical issue
el_oso
PostPosted: 19:37 - 15 Apr 2012    Post subject: sv650 electrical issue Reply with quote
my friends sv650 will not start on the button. classic case of a dead battery. so we jump started and noticed that when the bike was revved up a little bit all the lights on the bike dimmed. we were a little concerned as to why the battery went flat as the bike is used regularly and we think is only around a year old. the bike was not left out in the cold over winter. the bike is fitted with an alarm so that will drain power.
is there a possible problem with the charging circuit? r a bad ground perhaps? or it is the dimming lights a normal thing if the battery is dead?
Duke 390
Car: Jeep Wrangler 4.0L
Budgetboy
PostPosted: 20:04 - 15 Apr 2012    Post subject: Reply with quote
Lights "Should" get brighter when you rev the bike to approx 3-4k
It might be that the battery is just flat atm so not enough charge.. As you put the load on it drains the battery so the lights dim.
Get it charged and see what it does after that if i were you.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
L4Isoside
PostPosted: 23:37 - 15 Apr 2012    Post subject: Reply with quote
Charge battery, check the voltage when its off and when its running Smile. If it dips when running, there be a fault with the regulator something (I forget the name, sorry).
Ghost
PostPosted: 23:44 - 15 Apr 2012    Post subject: Reply with quote
Regulator/rectifier Thumbs Up
The Artist
PostPosted: 07:15 - 16 Apr 2012    Post subject: Reply with quote
this
devojunior
PostPosted: 09:45 - 17 Apr 2012    Post subject: Reply with quote
The Artist wrote:
this
this +1
The last post was made 14 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 47.72 Kb
