Trusty YB100 not healthy
russeleoin
PostPosted: 13:37 - 16 Apr 2012    Post subject: Trusty YB100 not healthy Reply with quote
Hi All. I bought a new carb for my YB as the little fella(YB) seemed a bit down on power and the carb is definitly showing signs of wear. So I fitted it and now I have a strange problem. Starting the bike is a bit of an issue, it used to start on the 2nd kick, now it takes a while. Once started with the choke on, it is fine until it warms up, then it cuts out. Restart with the choke off and it will idle fine once warm but seems to have delayed acceleration, ie, twist and it takes a couple of seconds to rev. It didnt do that before. When warm and riding it feels down on power, but put the choke on and it is back to normal power but stop at the traffic lights and it cuts out. It will restart immeadatly with the choke off.
Now, I can go back to the old carb as I didnt have all of these problems, but it was not running as smoothly as needed hence changing the carb in the first place. I have checked the points, they are only a few months old, the gap is correct and the plug is good too. When running the bike is not running rich or lean. The battery is good, the only thing I am not sure of is the condenser? Do they degrade or just fail?
Thanks, Russ
I love classic merc's but bikes take up less space.
Current ride is a Yamaha YB 100 and I love it! Oooow and now a running GPZ400R!
Next stop, Direct Access hopefully by the end of summer.
timmy222
PostPosted: 14:11 - 16 Apr 2012    Post subject: Yb100 Reply with quote
Make sure the air pilot screw is 1 1/2 turns out.
Put the little c clip on the slide needle in the middle setting.
Try that first.
Make sure you try it with the carb cover back on the bike or the setting I said will not work.
russeleoin
PostPosted: 14:24 - 16 Apr 2012    Post subject: Reply with quote
Agh fek, thanks Timmy, now you mention it I didnt check the settings at all. I made sure it was clean, and just stuck it in. Shite what a dimwit. Embarassed
russeleoin
PostPosted: 21:29 - 16 Apr 2012    Post subject: Reply with quote
So I have had a look at the settings and I notice that the old carb has a 2.5 mark on the underside of the slide, and the new carb has a 3.0. Can anyone tell me what these mean, and the needles look identical. Thanks
The last post was made 14 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 39.38 Kb
