help help help help help!!! please!!!!
Biker_Dene
PostPosted: 17:42 - 01 Oct 2004    Post subject: help help help help help!!! please!!!! Reply with quote
i contected all my petrol tank up and started my engine for the firct time today since my crash and after a few seconds petrol started to oose out of the breether/over flow piep or that are conected to the carb 3 pipe
so i turned the petrol tap off and it stoped turned it back on and it started to poor out again ?? the buike started and ticked over just fine so what could it be ????????????????? please some 1 help me out Sad
"RIDE LIKE A KNOB AND YOU'LL DIE"
K9 Suzuki Hayabusa
Biker_Dene
PostPosted: 17:42 - 01 Oct 2004    Post subject: Reply with quote
sorry for double posting Embarassed
K9 Suzuki Hayabusa
Hex
Party Boy
PostPosted: 17:52 - 01 Oct 2004    Post subject: Reply with quote
Have you connected the breather hose to the wrong point?
Sounds simple doesn't it, but I've did it before.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Biker_Dene
PostPosted: 17:54 - 01 Oct 2004    Post subject: Reply with quote
the breather hose that goes from my tank doesnt conect to anything just hangs free and i dont no aboutthe carb wen i took the carb off all i had 2 do waz undew the aoil and petrol pipes and take it off
its a 35mm mikuni tmx i think
K9 Suzuki Hayabusa
Hex
Party Boy
PostPosted: 17:56 - 01 Oct 2004    Post subject: Reply with quote
If its directly connected to the carb, then its likely the carb float has stuck.
Give the carb a few knocks and see if it releases it or strip it down and clean the float bowl out.
Biker_Dene
PostPosted: 17:58 - 01 Oct 2004    Post subject: Reply with quote
ok thnkx but iv had the carb apart and cleaned it quite recentley
but i will have another look
any more ideas?
K9 Suzuki Hayabusa
Hex
Party Boy
PostPosted: 18:01 - 01 Oct 2004    Post subject: Reply with quote
It only would take a tiny bit of grit to stick it open.
Check you haven't bent the float when you had it apart last.
swampy
PostPosted: 18:26 - 01 Oct 2004    Post subject: Reply with quote
Like hex said, sounds like the float has stuck down, (like a ballcock in a toilet cistern) so is not stopping petrol entering the bowl. Therefore the bowl is over flowing, and you have a boot full of petrol Smile
Biker_Dene
PostPosted: 18:30 - 01 Oct 2004    Post subject: Reply with quote
ok thnx guys ill have a look tomorrow
K9 Suzuki Hayabusa
Frost
PostPosted: 18:38 - 01 Oct 2004    Post subject: Reply with quote
make sure your fuel isnt turned onto reserve, ive found that it you fill a bike up with fuel and leave it on reserve fuel can piss out of the breather
PostPosted: 18:55 - 01 Oct 2004    Post subject: Reply with quote
Hit it with a hammer.
If you give the affected carb a few taps with a deadblow hammer, it can allow stuck floats to settle themselves down properly or dislodge a bit of grit from the needle valve. Do it whilst the fuel is running out, you will know if you have been successful because the flow will stop. You sometimes have to repeat this a few times if they are being stubborn.
The last post was made 22 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 67.78 Kb
