Bike Stood for a long time, not starting - SOLVED!!!
.Bishbash.
PostPosted: 16:21 - 16 Apr 2012    Post subject: Bike Stood for a long time, not starting - SOLVED!!! Reply with quote
Hi,
Bike: 2008 YZY-R1 - Fuel Injected
Got all my parts(new ignition & ECU) for my R1 now, all fitted, it turns over which is a start. I have replaced the fuel, charged the battery and it doesn't fire. It has been stood for 10 months.
Any good tips for getting it started? Or shall I just keep trying to turn it over?
Thanks!!!
Current bike - GSX-R1000 k8
The Artist
PostPosted: 16:56 - 16 Apr 2012    Post subject: Reply with quote
New set of plugs?
Also I will get flamed for this but a little squirt of easy start for the first time won't do much harm and if it runs for a second and then cuts out, you know it is a fuel issue. If it doesn't run at all, you know it is an electrical issue.
.Bishbash.
PostPosted: 11:54 - 17 Apr 2012    Post subject: Reply with quote
Yeah I was thinking the plugs, pain in the backside to get to though.
You wont get flamed, good thinking with the easy start, i'll try that. Where do you squirt it on a fuel injected bike? Down the intakes under the tank like you would on a carbed bike? Or is it different?
Thanks
andym
PostPosted: 12:28 - 17 Apr 2012    Post subject: Reply with quote
When I bought my intruder 125 that wouldn't start after sitting for almost 3 years... I left the fuel that was still in there, didn't really do anything to it to be honest, because I hadn't paid for it at that point I was told not to touch anything... anyway me and a friend just turned the idle up as high as it would go then tried bump starting it on a small hill... on the third attempt it started.
Not a solution, just an idea
D O G
PostPosted: 12:41 - 17 Apr 2012    Post subject: Reply with quote
I'm a dumbo, but it is either spark or petrol. Does it have both? Have you tested this? Any other suggestions are pointless unless you know what the actual issue is.
.Bishbash.
PostPosted: 13:39 - 17 Apr 2012    Post subject: Reply with quote
It has 5 litres of fresh fuel in there. More info may help, here it comes;
So a bit of background first;
Bike got stolen over a year ago, I got it back...YEY...The ECU was missing and ignition was broken, so I replaced the whole lockset. Replaced with new fuel.
So, it all turns on, turns over but does not fire. There is a different look to the dash though. The temperature is stating 'HI' The fuel light is flashing(not normal), even though there is 5 liters of fresh juice in there AND I noticed the imobileser light doesn't flash anymore when the ignition is set to off.
Any ideas? Will a ECU reset work? I have the magic red key, but have no idea what to do with it, turns out putting it in the ignition and hoping doesn't cut the mustard!
PostPosted: 13:43 - 17 Apr 2012    Post subject: Reply with quote
Check the silly things, clutch/ sidestand etc. and the associated kill switches. Maybe crank it with a plug out and earthed to see if you are actually getting a spark. I wouldn't bother changing the plugs unless they needed doing before hand.
P.s. google is your friend
haffed / broken or shorted imobilizer wire......... thats the problem... shows as hi temp and wont start....
happened to mine awhile back, mine was worn through by the radiator upper bracket that the imobilizer wire runs next to.... a quick bit of soldering and re-routing the wires worked for me.....
cut back the outer sleave next to the bracket... mine was cut under it but only showed as a little bit of a rub mark on the outer sleave....
https://www.r1-forum.com/forums/showthread.php?t=301653
CaNsA
PostPosted: 13:46 - 17 Apr 2012    Post subject: Reply with quote
How long did you try to start it for?
Can take a few goes for the fuel to be where it needs to be.
MaybeGuy
PostPosted: 13:54 - 17 Apr 2012    Post subject: Reply with quote
Did you plug the fuel pump in? The flashes will probably be a code.
D O G
PostPosted: 15:11 - 17 Apr 2012    Post subject: Reply with quote
In the tank, but is it getting to the cylinders?
Do the plug out test as per chris-red to see if it has spark. If none, then diagnose that (easier said than done). If it has spark, then it must be a fuelling issue, so diagnose that (again, easier said than done).
.Bishbash.
PostPosted: 16:24 - 17 Apr 2012    Post subject: Reply with quote
Super stuff Chris, thanks for that, strangely I am on that forum and searched it. Must be me.
It certainly makes sense for the immobiliser wire to be cut if the would-be-theif was that dumb.
I will give the bike a once over and check the plugs out as well, but as these bikes are SO smart these days would it spark if that wire was cut/damaged? Just a thought, I don't know what it shuts off if it has been tampered with.
Thanks for the help so far chaps.
.Bishbash.
PostPosted: 15:37 - 30 Apr 2012    Post subject: Reply with quote
Solved the little trickster, it was indeed a severed wire on the immobiliser wire, tip of the cap to you Chris! I soldered it back up and she runs a treat now.
It was the wire that runs off the key set I bought, and not on the wire on the bike which I thought it could have been. Who would have thought. Rolling Eyes
Oh and the flashing fuel light was my fault as when I put the tank back on I didn't put the electrical cables back on the connectors. Embarassed Embarassed
It spluttered and struggled to start with, then ran as per normal.
HAPPY DAYS! Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
PostPosted: 16:25 - 30 Apr 2012    Post subject: Reply with quote
FUCK YEA.
Dom is frantically wanking now...
0l0dom0l0
PostPosted: 16:37 - 30 Apr 2012    Post subject: Reply with quote
##Paddy## wrote:
FUCK YEA.
On the 4th since the text he sent me saying it was running Wink
PostPosted: 16:41 - 30 Apr 2012    Post subject: Reply with quote
Laughing Like a boss.
Bishbash, would much like to give an R1 a spin Wink
.Bishbash.
PostPosted: 23:18 - 30 Apr 2012    Post subject: Reply with quote
Paddy, I bet you would....Dom you got the ride mate, just got to get it roadworthy now....not long Wink
The last post was made 14 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 90.64 Kb
