High idle problem
grant965
PostPosted: 20:49 - 16 Apr 2012    Post subject: High idle problem Reply with quote
Hi, after replacing all 4 inlet rubbers because old ones were cracked I am getting a 4k idle when its suppose to be around 1.5k.
Throttle sits at lowest setting on the carbs and the idle adjuster is fully out, so in theory, the bike should be stalling not idling too high.
Its a yamaha thundercat, carbed bike.
Any ideas?
Thanks in advance, Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
The Artist
PostPosted: 20:54 - 16 Apr 2012    Post subject: Reply with quote
Air leak around the rubbers. Air is getting into the intake after the carbs.
grant965
PostPosted: 20:55 - 16 Apr 2012    Post subject: Reply with quote
Can you suggest anything to check where the leak is? Is it common for an air leak on one could to the second one? Or is it a case that both are leaking?
thanks, Grant
The Artist
PostPosted: 21:25 - 16 Apr 2012    Post subject: Reply with quote
Get an aerosol, nothing too flammable but deodorant or something would be fine. Spray on each intake rubber with the engine running and the engine will rev up more when you spray on or near the leak.
Fizzer Thou
PostPosted: 09:41 - 17 Apr 2012    Post subject: Reply with quote
Are the throttle cables routed the same way as before the inlet rubbers were replaced?
Did you have to compensate with a higher idle speed before you replaced the inlet rubbers?
Always have a 'Plan B'
grant965
PostPosted: 09:46 - 17 Apr 2012    Post subject: Reply with quote
The actual throttle body on the carb is fully back, and so Im 100% positive it is not the throttle cables or the idle adjuster as that is right out.
I have never had to alter any idle speed. However, if Im sat in traffic on a hill the idle speed drops, sounding similar to a cold engine or an engine thats going to stall, even though it never does, could they be linked?
reckless_b
PostPosted: 09:47 - 17 Apr 2012    Post subject: Reply with quote
Have you looked at the throttle cable, when you removed the carbs to change the rubbers did you alter its setting, is the throttle linkage sitting on its stop
40 years on the road on and sometimes off bikes with a very recent OFF
reckless_b
PostPosted: 09:50 - 17 Apr 2012    Post subject: Reply with quote
Did a previous owner screw out the pilot mixture screws to overcome the leaky carb rubbers, is the choke fully closed.
grant965
PostPosted: 12:22 - 17 Apr 2012    Post subject: Reply with quote
Even with throttle disconnected it was the high idle.
I will give the mixture screw ago.
thanks
The last post was made 14 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.41 - MySQL Queries: 13 - Page Size: 59.52 Kb
