Yamaha fazer ignition lock, need to replace.
carl_easykart
PostPosted: 21:42 - 16 Apr 2012    Post subject: Yamaha fazer ignition lock, need to replace. Reply with quote
Hello has anyone change an ignition lock on yam fazer 600 2002. Mine is playing up so need to change it. Is it a hard job to Do?
Thanks carl
janner_10
PostPosted: 23:14 - 16 Apr 2012    Post subject: Reply with quote
Is it your barrel playing up?
If so, the dip the key in some oil and push it in and out a few times and repeat 2 or 3 times. Mine would never go down far enough to engage the steering lock until I loosened it up like this.
st3v3
PostPosted: 00:59 - 17 Apr 2012    Post subject: Reply with quote
Is it a full complete part?
https://www.patternparts.net/Thumbnail/Default.aspx?file=/upload/images/738822.jpg&width=400&height=300
Based on that if it is then a couple of bolts undone would sort it.
You had a glance anywhere else?
https://foc-u.co.uk/index.php?topic=756.0
carl_easykart
PostPosted: 07:29 - 17 Apr 2012    Post subject: Reply with quote
I have tryed everything it's come to a point now that it's turning to the ignition point but the bikes not starting and I can pull the key out when I couldn't do that before. Thanks for your help though Smile
carl_easykart
PostPosted: 07:32 - 17 Apr 2012    Post subject: Reply with quote
Hello yes it's the complete part like that. I will have a nose on that forum thanks for your help
Fizzer Thou
PostPosted: 09:18 - 17 Apr 2012    Post subject: Reply with quote
Some ignition switches get to that stage where replacement is the only way.
Strangely,Wemoto do not specify a switch for the Fazer 600,but M&P do
https://www.mandp.co.uk/productinfo.aspx?catref=508769&tier1url=Spares&tier2url=Ignition-Switches&tier3url=Economy&tier4url=Ignition-Switch
When I last had to replace a switch there were some security bolts in place with very strong threadlock.In the end I had to drill the heads off and use a stud removal tool to get the remains out of the top yoke.
Always have a 'Plan B'
Cadbury
PostPosted: 09:51 - 17 Apr 2012    Post subject: Reply with quote
Also, don't forget that if you replace the ignition, that means you will have to have 2 keys - 1 for the ignition, 1 for your seat lock.
I have a Fazer, and also thought id need a new ignition, as I couldn't get my steering lock to initiate. Thankfully the 'dipping in oil' trick, and finding the sweet spot for the steering lock now means i'm fine.
The last post was made 14 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 53.52 Kb
