Noob Air Compressor question
Nick 50
PostPosted: 13:28 - 17 Apr 2012    Post subject: Noob Air Compressor question Reply with quote
So I've bought and air compressor which got delivered today. After adding the all the bits on with the use of the completely useless manual, I now have a question.
The compressor has 2 connectors:
https://webstore.toolsandpowertools.co.uk/pics/ebay/hy2550/twin%20output.jpg
Can I just connect hose then tool to either one? and the stupid question, what do I do with the other connection??
Or am I missing something that should be attached to the connectors?
Raffles
PostPosted: 13:42 - 17 Apr 2012    Post subject: Reply with quote
It is usual to have a PCL type push-in connector as an outlet from a compressor.
https://youngautomotivedirect.co.uk/images/100_series_coupling.JPG
Nick 50
PostPosted: 13:48 - 17 Apr 2012    Post subject: Reply with quote
Do they have stop valves in them?
I put oil and let it run a bit and air was pissing out the holes Shocked
MarkJ
PostPosted: 14:30 - 17 Apr 2012    Post subject: Reply with quote
I have two outputs on my compressor. One you can control the pressure of with the red tap that you have there, the other is just full power. I assume your full power one is the one on the right as it has the release valve there.
Nick 50
PostPosted: 14:46 - 17 Apr 2012    Post subject: Reply with quote
Cheers Mark. So I just add two PCL female connectors and then i'm ready to go?
MarkJ
PostPosted: 14:49 - 17 Apr 2012    Post subject: Reply with quote
Depends what hose connectors you've got, but as Raffles said they normally are fitted with the pull-to-release type connector he has pictured (at least all the ones I've seen have them fitted).
If you've got some air leaks from threads you might have to use breakable threadlock. My air tools specified I did.
PostPosted: 14:56 - 17 Apr 2012    Post subject: Reply with quote
or PTFE tape Thumbs Up
The last post was made 14 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 52.59 Kb
