Stubborn Chain Adjuster
Renton
PostPosted: 17:30 - 15 Apr 2012    Post subject: Stubborn Chain Adjuster Reply with quote
Bike: SV650S K2
The right hand chain adjuster on my SV will not budge. I have tried leaving it soaking in penetrant lubricant, but that does not seem to have worked.
I'm worried if I keep forcing it with the allen key that I will just round it off.
Can anyone offer some other suggestions please?
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
Suntan Sid
PostPosted: 17:34 - 15 Apr 2012    Post subject: Reply with quote
Post a pic please.
lihp
PostPosted: 18:02 - 15 Apr 2012    Post subject: Reply with quote
After doing a chain and sprockets on a friends SV last weekend, I made the stupid mistake of not loosening the pivot for the rear brake caliper. Make sure that you loosen the pivots for the caliper so that it can move when you turn the adjusters, otherwise your wheel ain't going anywhere.
Renton
PostPosted: 19:25 - 16 Apr 2012    Post subject: Reply with quote
This is not my bike, but it is exactly the same:
https://static.flickr.com/2432/3954633230_62f89aaeff_m.jpg
If you meant a picture of my bike specifically I can do this tomorrow night.
Everything is loosened as it should be, apart from the aforementioned adjuster.
herulach
PostPosted: 19:56 - 16 Apr 2012    Post subject: Reply with quote
When the one on the fazer did that I just dropped the wheel once there was no load on it it moved reasonably freely and was unwound then liberally greased before reassembly.
YBR 125>FZS600
Suntan Sid
PostPosted: 21:36 - 16 Apr 2012    Post subject: Reply with quote
If you're not already using one, use an allen key socket, and whack it round with a mallet, a sharp hit is best.
If you round out the hex hole, hammer in a star bit and a sharp crack with a mallet.
darren997
PostPosted: 12:51 - 17 Apr 2012    Post subject: Reply with quote
+1
Renton
PostPosted: 10:29 - 23 Apr 2012    Post subject: Reply with quote
Sorry to drag this back up. Only just getting round to addressing the issue.
Have asked a fella in the garage at work, and he suggested we heat up the surrounding area to release the screw, which I know works. But he said I would need a new bolt/screw. Also said I would need to replace the bolt if we tapped it with a star piece.
I have tried searching for the replacement bolt/screw, but I can only find the whole assembly. Will I need to replace anything?
Renton
PostPosted: 10:45 - 23 Apr 2012    Post subject: Reply with quote
Just tried an Allen socket, and rounded the head out
Going to try heating up or tapping a star piece in to it tomorrow morning.
herulach
PostPosted: 17:46 - 23 Apr 2012    Post subject: Reply with quote
Have you taken the wheel out yet? That and a torx bit should have it out.
YBR 125>FZS600
Renton
PostPosted: 16:18 - 24 Apr 2012    Post subject: Reply with quote
Lifted the back end and tried again with a torque bit. Still now luck.
The bolt just will not budge.
Do I have to take the wheel out now? Also, would I need to replace the now rotten bolt?
The last post was made 13 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 67.43 Kb
