| Flatbadger |
 Flatbadger World Chat Champion
| Derivative |
 Derivative World Chat Champion
| Flatbadger |
 Posted: 00:07 - 20 Apr 2012 Post subject: |
Suzuki DR 125, 4 stroke engine. It's that messy bit I don't fancy, also I end up with a load of sump oil which I imagine is awkward to get down the dump on the bike! But if I must do that, does anyone have any tips?
I'd rather be lazy for now to be honest  |
| Gazza M |
 Gazza M Crazy Courier
| Flatbadger |
 Posted: 00:39 - 20 Apr 2012 Post subject: |
Well if that draining lark is necessary, then it will have to be. I'll be off to Halfords (on my pushbike ) for the oil, and I'll get a funnel while I'm at it. Bah!
Thanks for your answers  |
| Nick_Giles |
 Nick_Giles Could Be A Chat Bot
 Posted: 00:48 - 20 Apr 2012 Post subject: |
| Flatbadger |
 Posted: 00:58 - 20 Apr 2012 Post subject: |
I've been on a learning curve lately, and I'd like to keep it as shallow as my personality! There's a limit to new things I can handle before encountering stress, and this is an exciting new world!
Take pity on a frazzled starter, I worry that I won't be able to pick the bike up and stand it upside-down to change the wheels like my mountain bike! |
| janner_10 |
 janner_10 World Chat Champion
| _Iain_ |
 _Iain_ Banned
 Posted: 02:34 - 20 Apr 2012 Post subject: |
Link in my sig covers an oil change and service on a YBR.
I'd imagine that it's 90% the same on your bike, besides the bit about valve clearances & the air filter.
Given i was quoted £140 for a service on the YBR, and paid £30 for the parts to do it myself....i'd say its worth having a crack at.
Also covered is disposal of the old oil in the easiest manner possible. ____________________ Please be aware that the above post may be full of complete nonsense.
| tomh |
 tomh Scooby Slapper
 Posted: 06:25 - 20 Apr 2012 Post subject: |
Quick question:
How are checking the oil level? If you are using the side stand, the oil in the sump won't be level meaning using the dipstick will give you a empty reading. I've panicked before when I've checked the oil level like this and thought I was running the bike empty
You need to check the oil using the center stand if you have one on a flat surface.
Another thing when checking the oil is to check it once the engine has cooled down and the oil has returned to the oil sump. Although when you actually change the oil, you would do it while the engine is hot.
Sorry if you already know this but there very easy mistakes to make.
If you're going to top the oil up just use semi synthetic 10w40. It's what's most likely already in and it will certainly not have anything designed for a diesel engine in it. It will also make no difference if you mix 15w40 with 10w40 if you're going to get a full oil change done soon anyway. |
| Flatbadger |
| Elffie01 |
 Elffie01 Nova Slayer
 Posted: 10:03 - 20 Apr 2012 Post subject: |
Well Im not a total feeble old woman but in about 40 years I might be there ! so I will say...Have a go
I changed the oil on both my 125's and being a complete newbie to bikes its pretty easy when you find you capacity. Do as Gazza said..
pretty sure the oil sump capacity is 1l - if it is, buy a bottle of new stuff, drain the current into a pan, fill up with the whole 1l bottle of new stuff, then empty old oil into the litre bottle and take to to the dump.
simples.
One tip : Don't leave the drained oil under the hole then proceed to drop the spanner into it....messy messy !
good luck, its easy. If i can do it anyone can.  |
| kernow24 |
 kernow24 Crazy Courier
 Posted: 11:54 - 20 Apr 2012 Post subject: |
I'm confused as to why you've needed to use a torch and
trying to slosh it around to see the level, which would be
nigh on impossible anyway, 125's have very little oil in, so there
will be no sloshing, and will be impossible to judge the level
by looking in with a torch.
Surely you have a dipstick or glass level of some description,
I've never had a bike that didn't have one or the other.
When you removed the oil filler cap, its probably got a dipstick
built in, with min / max marks. Wipe it off, place it back without
screwing it on and then check the level, simples.
It 'should' be fine anyway, engines lose minute amounts of oil,
and if its used loads you would have known about it, and you
would have a lot more to worry about than getting a 'pro' to do an
oil change
Oil changes are simple, even for someone like yourself that's overly
cautious about it.
You've pretty much done it with trying to check the oil, its just one
other bolt and its done.
As someone has pointed out, servicing by a garage is expensive, 120
quid or more with what would cost you 20 to 40 quid in parts on a 125
and an hour of your time.
There's very little that can go wrong with servicing yourself (ooooer) and
it really is worth looking in to going forward. Don't require any special tools,
a socket set and some spanners will do the lot |
| kernow24 |
 Posted: 12:04 - 20 Apr 2012 Post subject: |
oil change
cautious about it.
| Flatbadger |
| Flatbadger |
 Posted: 18:03 - 20 Apr 2012 Post subject: |
I just tried checking it again in daylight, and it's more towards the full than the empty - I can't account for what I didn't see there last night!
https://i43.tinypic.com/1z1tt2h.jpg
So its there but looks a bit dark - this'll do til Tuesday right? I'm planning on going about 25 miles tomorrow and again Sunday, then a couple of miles to the mechanic's.
I'll get that carlube back to the shop as well! |
| weasley |
 weasley World Chat Champion
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 18:12 - 20 Apr 2012 Post subject: |
Sorry if this is a bit late - but don't ever use oil intended for a car engine in a motorbike!
Motorcycle oil has additives to protect the clutch and gearbox - car oil doesn't.
Always change the filter at the same time you change the oil - and don't use additives like Wynnes or STP, and check the level with the bike upright - not cocked-over on the side-stand. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| Flatbadger |
| _Iain_ |
 _Iain_ Banned
 Posted: 21:04 - 20 Apr 2012 Post subject: |
Out of interest - how much is he charging you for this oil change & good service? And in reality, what could possibly go wrong with the bike that scares you so much doing it yourself? ____________________ Please be aware that the above post may be full of complete nonsense.
| Flatbadger |
 Posted: 21:25 - 20 Apr 2012 Post subject: |
It looks like a couple of hundred including a new rear tyre. The reason I'm doing it this way is above, it's in the bike's longer-term interests to have some initial attention by someone who knows already what they are doing.
Maybe I should go on a Christian forum and say I'm an atheist, I might get much the same response!
I'm planning on letting Jesus into my heart one day soon, and getting the jumper and tambourine to match. Of course I risk his return at any time, and being cast into the pit of brimstone but I just fancy a bit more hedonism first
I can understand your being as enthusiastic about working on your bikes as you are about saving money, but please let me come to that in my own time! |
| Nick_Giles |
| janner_10 |
| MG |
 MG Traffic Copper
| Flatbadger |
 Posted: 22:47 - 20 Apr 2012 Post subject: |
Last night I went about 7 miles and didn't go much over 30 as it's all built up. I locked the bike up and by the time I looked at the level it had been off a few minutes. It looked like the window was smudged by what looked like lard, and I couldn't see anything other than that. Maybe the torchlight was refracting in the glass..
Earlier I ran it in neutral for a few minutes, then turned it off for 2 or 3, I was following the little owner's manual - and got the level (above) with the bike upright. Broad daylight helps I suppose!
Well an oil change leads to an oil filter change, and what then? Swarfega! It's a slippery slope. Maybe I'll go to Halfords and have a look there, 10w40, petrol, bike.  |
The last post was made 14 years, 75 days ago. Instead of replying here, would creating a new thread be more useful? |
