Triumph Daytona 955i Clutch Cable Probs
newmannewy
PostPosted: 14:52 - 20 Apr 2012    Post subject: Triumph Daytona 955i Clutch Cable Probs Reply with quote
hi folks,
I cant get my clutch to adjust correctly. I have changed the clutch cable as it was at its furthest extension and whilst the fairing was off I figured I would change the clutch cable..
I have routed it the same as the old cable.. And it is a genuine triumph replacement part. I even measured the 2 together.. But for some reason the lifter arm isnt pulling the cable back. There are no bends in the cable.. Ive ran it through the bike several different ways and adjusted it each way back and forth 30 times. Yet nothing seems to work.
If I take the cable off the lifter arm the arm will retract back to its original position. But when the cbale is attatched it doesnt seem to have the strength to pull the cable back even though the cable is still quite lose..
Could this be a problem with the lifter arm spring not being powerfull enough to pull the arm back or is there something down in the clutch caseing that is stopping it being pulled back ?
I really didnt want to have to take the clutch casing off as that requires draining the oil again and buying a new gasket.. So does anybody have any other theories or suggestions before I go spending more money as to why the cable will not spring back ones pulled.
PostPosted: 15:00 - 20 Apr 2012    Post subject: Reply with quote
Sounds like there might be something wrong with the helper spring on the clutch lifter arm.
Personally, I'd buy a Venhill clutch cable first, and see if it is any better. But that's just me.
newmannewy
PostPosted: 15:54 - 20 Apr 2012    Post subject: Reply with quote
Cant be buying another cable, just spent £30 on this.
IS there anything in the clutch case that would be holding it back from returning ?
PostPosted: 18:49 - 20 Apr 2012    Post subject: Reply with quote
I think there is a clutch 'helper' spring in there. I suspect the only way to sort it is to remove the clutch cover and have a look.
newmannewy
PostPosted: 20:53 - 20 Apr 2012    Post subject: Reply with quote
yeah im gonna have to bite the bullet and buy a new gasket, new oil pan and drain the oil again. Grrrr
The last post was made 13 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 45.07 Kb
