float sticking
Usher4566
PostPosted: 20:07 - 23 Apr 2012    Post subject: float sticking Reply with quote
Why does.my float keep sticking .bike was running lean so changed float hight slightly now wen I rev bike it goes up like staving when I tap carb they go back down ans agen when I rev same ? It's had new float valve
New cd200 benly owner
lihp
PostPosted: 20:59 - 23 Apr 2012    Post subject: Reply with quote
Putting more fuel into the bowls won't make it run any richer, unless it was previously draining the fuel in the bowl.
Are they over filling? How did you come to the conclusion that it was running lean?
What have you investigated?
Usher4566
PostPosted: 21:09 - 23 Apr 2012    Post subject: Reply with quote
Been having problems since I bought was sooting up plugs so stipped carb.found wrong jet missing o ring and worn float valve so replaced and tester .took plug out found white hence lean in manual it says if you are experiencing too much fuel (rich) or to little (lean) you should fist check and adjust float hight?
Ariel Badger
PostPosted: 21:21 - 23 Apr 2012    Post subject: Reply with quote
Did you check the height or just prat about with it? Running lean could be down to an air leak, is your carb pulling in air?
Usher4566
PostPosted: 21:39 - 23 Apr 2012    Post subject: Reply with quote
Checked 14.5mm as per manual but keeps sticking now till tap carb then unsticks and sticks agen
P.
PostPosted: 22:21 - 23 Apr 2012    Post subject: Reply with quote
Carefully shave a mm or so around the float? so it stops sticking?
Is its the actual metal mechanism sticking?
temeluchus
PostPosted: 01:42 - 24 Apr 2012    Post subject: Reply with quote
Check the pin that holds the float isnt damaged.
Usher4566
PostPosted: 05:32 - 24 Apr 2012    Post subject: Reply with quote
Ok will check pin out .
Usher4566
PostPosted: 06:40 - 24 Apr 2012    Post subject: pic could the float jet be wrong way round Reply with quote
Hi if you look on pic it shows float jet I've put in how is on pic should it go other way coz has a bent wire top
Budgetboy
PostPosted: 09:02 - 24 Apr 2012    Post subject: Reply with quote
Whilst the float height mat be one of your problems for running lean, are you sure the fuel Air mix is set correct?
If the floats are sticking in the top (shut) position you need to take the float pin out.Turn the float valve around the other way, and reset the float height.
Hold the carb in your hand the proper way up and test it to see if it sticks.
make sure the float pin is clean and has no scratches in it as this will cause the float to stick.
www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken.
Usher4566
PostPosted: 09:20 - 24 Apr 2012    Post subject: Reply with quote
Ok will try tuning wen dry ir screw set to 2 turns as per manaul
Budgetboy
PostPosted: 09:32 - 24 Apr 2012    Post subject: Reply with quote
Screw it ALL the way in then 2 turns out. Thumbs Up
Usher4566
PostPosted: 11:39 - 24 Apr 2012    Post subject: Reply with quote
Ment turning float valve.air screw reset already just gta stop that float sticking .where do u guys measure float from Haynes says back where joins
Usher4566
PostPosted: 15:54 - 24 Apr 2012    Post subject: Reply with quote
If revs are going up .I tap carb they come down does that meen the float is stickingclosed
Usher4566
PostPosted: 18:32 - 24 Apr 2012    Post subject: update help why !!! Reply with quote
Wad sitting there today and was thinking this over that the float seems great when carb open so thought why well the new float jet I put in had a bigger spring bit thanold thought maybe old worn so then got think bout fuel so thought maybe not anougth pressure to push spring u get me ? No well any way just put 7 squid in and turned tap to on and started bike wen I started was same till bout 60 seconds then revs dropped back to normal revs up a treat .could this be blocked reserves isthere a seperate tube could it be to tight spring on carb jet ? Any comments
The last post was made 13 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 4.92 - MySQL Queries: 13 - Page Size: 82.83 Kb
