ignition switch for MZ TS125
wisebeuy
PostPosted: 23:45 - 02 Oct 2004    Post subject: ignition switch for MZ TS125 Reply with quote
Am currently rebuilding this bike, but have noticed something a bit... odd.
There does not seem to be an ignition switch. All I can see is a knob on the top of the headlight which can turn left and right in about 5 positions. There is a keyed compartment or something on the left side under the petrol tank, but that is all. Any ideas?
PostPosted: 13:03 - 03 Oct 2004    Post subject: Reply with quote
The knob in the top of the headlamp is the key, it should pull straight out when in the middle position.
The key itself looks like a kind of metal tube with a notch cut in the end and the kind of teardrop shaped, plastic knob on the other end.
As I remember (I am a bit vague on this so don't take it as gospel) the central position is 'off', turn one way (clockwise, I think) for 'on' and the other way for 'emergency' which should allow you to start the bike with a flat battery or bump start it (the normal 'on' position needs charge in the battery to power the coils initially). I think on some models it may also switch the lights on if you turn it another notch round from 'on'.
Switch labelled 4(a) on This diagram (which is for a slightly different model.
You will find this site useful, they are in germany and are very helpful, parts usually arrive within two working days.https://www.mz-b.de/mz/emz.htm
The last post was made 22 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 32.45 Kb
