Cat B bike, swapping frame?
grant965
PostPosted: 21:25 - 24 Apr 2012    Post subject: Cat B bike, swapping frame? Reply with quote
Hi, am i right In thinking a cat b registry is only recorded against the frame? So in theory i can swap a bike to a 'clean' frame?
Reason I ask is there is a bike on ebay that says it is a stolen recovered and has been fixed but is cat B.
If not, what out of a cat b engine can be salvaged?
thanks
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
MaybeGuy
PostPosted: 22:11 - 24 Apr 2012    Post subject: Reply with quote
It's perfectly fine to do so, I had to do this on my R6 when I bent it. Just fill out the V5 for the new frame with the old engine number. Obviously you'll be using the other frames numberplate.
grant965
PostPosted: 22:15 - 24 Apr 2012    Post subject: Reply with quote
thanks for the reply, the frame and engine numbers have been removed by the salvage company, if I leave the engine section blank does it go to a q-plate? Or can I get away with the frames details for a normal reg?
mad4it028
PostPosted: 23:02 - 24 Apr 2012    Post subject: Reply with quote
sounds dodgy as fuck to me , i buy alot of bikes from insurence and cat b bikes are normally totally beond repair only breakers can buy them and trust me if he bought it as a breaker its worth more to him in bits
oh and insurence companys dont remove numbers
i sujest you be very carefull as sounds like you may be buying a stolen bike make sure you see paperwork from the insurence company
ringing bikes if caught can carry a sentence!
PostPosted: 23:19 - 24 Apr 2012    Post subject: Reply with quote
Agree with the above. While they might destroy the chassis number or make it obvious it is a write off I can't see them bothering normally (except maybe a breaker trying to hide that it came from them), but no real reason to destroy the engine number as the engine should be able to be used.
MaybeGuy
PostPosted: 23:21 - 24 Apr 2012    Post subject: Reply with quote
I thought a stolen/recovered bike with the engine numbers ground off was written off as a cat B by default?
PostPosted: 23:38 - 24 Apr 2012    Post subject: Reply with quote
Not sure, but that would be the tea leaves removing the ID rather than the insurer.
grant965
PostPosted: 09:05 - 25 Apr 2012    Post subject: Reply with quote
is it a sure bet if i break for parts? its £150 with everything intact other than frame numbers.
Would get my money back + more n the fairings alone.
The last post was made 14 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 58.99 Kb
