zzr600 rear caliper
Mrjoolz
PostPosted: 14:51 - 23 Apr 2012    Post subject: zzr600 rear caliper Reply with quote
Need overhaul of rear caliper and wondered if I buy the seal kit from wemoto (consists of 2x dust seals and 2 x piston seals), will this be sufficient ?
Do I need to split the caliper and if so, do I need the seal that goes between the two halves, or will I get away with just the dust and piston seals.
The dust seals on there at the moment, are starting to creep out along side the pistons, so needs to commence work a little sharpish.
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
PostPosted: 17:38 - 23 Apr 2012    Post subject: Reply with quote
Is it a D or E model. On the E I think it is just a single piston sliding caliper which isn't able to be split.
Mrjoolz
PostPosted: 08:29 - 24 Apr 2012    Post subject: Reply with quote
Hi Keith,
Sorry its an E model. Yes you are right, I downloaded all the microfiches last night and checked, and its a sealed unit, so only the dust and piston seal need doing. (no o ring like on the front)
Many thanks for coming back to me. Had a feeling you would know.
Joolz
Fizzer Thou
PostPosted: 22:53 - 24 Apr 2012    Post subject: Reply with quote
It is a good idea to get some seal grease to cover the new seals with when you go to install them.This makes the cleaned up pistons easier to reinstall and staves off some corrosion to a degree.
When you remove the old seals,make sure that any old dust/crud buildup behind the seals is cleaned out otherwise the pistons will seize in the bore quicker than normal.
Always have a 'Plan B'
swanny
PostPosted: 23:08 - 24 Apr 2012    Post subject: Reply with quote
was pretty much a tyearly job on my zzr, they love binding and getting full of rubbish, pretty easy when you have them off though
M SWANNY.. see a sig !
Robby
Dirty Old Man
PostPosted: 07:03 - 25 Apr 2012    Post subject: Reply with quote
If the piston has rusted then it should be replaced as well. MandP do a piston and seal kit, last time I bought one it was about £15.
The last post was made 13 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.2 - MySQL Queries: 13 - Page Size: 47.34 Kb
