Almost Down...
Lostboy02
PostPosted: 20:20 - 26 Apr 2012    Post subject: Almost Down... Reply with quote
So early this morning, on my way to work down some country lanes, I was being harrassed by some T*** in an Audi Q7 and almost dropped the bike on the corner..
Felt the back wheel going out from under me and had to catch it with my foot before it dropped!
What is the best way to take a corner ( Stupid question i know ) but please humour me lol
Thanks all
mab
PostPosted: 20:29 - 26 Apr 2012    Post subject: Reply with quote
Get your speed to the correct speed for the corner before you get to the corner.
Adjust your body position
Slight bit of throttle whilst in the corner increasing as you come out of the corner
Remember: "slow in, fast out"
Sounds like you were going too fast for the conditions. Would of been best to pull over and let the audi past
nick_houghton
PostPosted: 20:30 - 26 Apr 2012    Post subject: Reply with quote
Don't brake in the corner!
Nick Houghton
Lostboy02
PostPosted: 20:31 - 26 Apr 2012    Post subject: Reply with quote
I actually worried that id slowed down too much on the corner, ill just have to put it down to experience!
Shook me for a moment, but we all have to start somewhere right!
Thanks for the reply Smile
Irn-Bru
PostPosted: 20:44 - 26 Apr 2012    Post subject: Reply with quote
If someone is harassing you, or forcing to ride in a way which you aren't comfortable with, pull over and let them pass Thumbs Up
GrumpyGuts
PostPosted: 21:40 - 26 Apr 2012    Post subject: Reply with quote
+1. I did exactly that and ended up giving the asphalt a great big hug Embarassed
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
PostPosted: 23:09 - 26 Apr 2012    Post subject: Reply with quote
Your cornering will be much smoother when you don't have a Prat Bus up your backside.
If you're being hassled, either pull over, slow right down until they finally get up the bottle to pass, or for bonus larks, swing to the RHS of the road and brake to make them undertake. Wink
Taught2BCauti...
PostPosted: 07:05 - 27 Apr 2012    Post subject: Reply with quote
Sometimes, the only option is to pull over safely and let the idiot pass, but most of the time, you should be able to keep well ahead by planning your position and speed into and out of the corners well in advance - same technique as for a car, but you have a lot more road to play with on a bike Smile
Videos like these might help:
https://www.youtube.com/watch?v=96MM_4Jxkjg&feature=related
https://www.youtube.com/watch?v=Rb2gZVuoNU4&feature=endscreen&NR=1
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Hokum
PostPosted: 09:20 - 27 Apr 2012    Post subject: Reply with quote
Cornering is all about judgement. There is a fast left-right bend near where I live which with my MPV I can only take at about 30mph, on my 50cc weed whacker scooter I can do it at 40mph.
It’s all about getting your weight and position right on the bike as much as it is about speed and grip of the bike. Look ahead and well into the corner. I remember a biker years ago telling me, look where your going and the bike will follow Smile
Sane: To know when you are doing something crazy.
JoeDougieDoug...
PostPosted: 13:03 - 27 Apr 2012    Post subject: Reply with quote
Knee down, rear wheel on fire at 200mph Thumbs Up
But srsly, just take corners easy - slow down before it, lean into it and accelerate out. Don't brake if you are in a corner, it WILL end badly. If you do need to brake in a corner, get the bike upright as quick as possible and if you find yourself going too fast into a corner then just lean it through, the bike will hold. Smile
sidewinder
PostPosted: 13:08 - 27 Apr 2012    Post subject: Reply with quote
When on my rospa assessment last week end they said you can brake in a corner?
stephen_o
PostPosted: 13:39 - 27 Apr 2012    Post subject: Reply with quote
check your tyre pressure, i nearly had an off on a fast a road corner when the bike wobbled, turned out my front tyre was nearly flat
current scoot 2009 Yamaha YBR250 + Current Pootle 2013 Nissan Leaf
Alpha-9
PostPosted: 13:50 - 27 Apr 2012    Post subject: Reply with quote
Be in the right gear to have enough power to pull yourself straight out the corner.
Look where you want to go, don't look at the curb!
Use the throttle to control your speed going through, not the brakes unless you HAVE to
Play around on smaller corners you're familiar with and get a feel for them! Rear brake and drop a gear and see what happens when you try and turn Laughing Danger!
I really think experimentation is a big helper for me.
I miss my bike now, feels like it's been forever Crying or Very sad
Fzr-600 1999
Taught2BCauti...
PostPosted: 18:13 - 27 Apr 2012    Post subject: Reply with quote
Yes - you can brake whilst cornering, but you need to fully understand what happens to the bike when you do, and how to counter it, so you don't end up rubber-side-up.
The effect will vary with different bikes, riders and road conditions - so best to practice gently somewhere safe to determine what works best for you.
Alpha-9
PostPosted: 22:57 - 28 Apr 2012    Post subject: Reply with quote
Once you've skidded the back wheel a couple of times by mistake you get used to the feel of it and the limits of the brakes
Don't overthink it Thumbs Up
Fzr-600 1999
Jynister
PostPosted: 23:18 - 28 Apr 2012    Post subject: Reply with quote
People driving up your backside can be an issue but just forget about them. If your in front of them on the road you have every right to ride in a way you feel comfortable with, because if you bin it they won't be picking up the tab for you.
Next time you feel like you've taken a corner too fast just lean more.
The last post was made 14 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 98.44 Kb
