Best graphics card for round about £100
Colin Edwards
PostPosted: 16:23 - 27 Apr 2012    Post subject: Best graphics card for round about £100 Reply with quote
As the title says I'm after the best graphics card I can get for the £100 mark..
Suggestions appreciated..
Thanks
andym
PostPosted: 16:47 - 27 Apr 2012    Post subject: Reply with quote
Geforce GTX 550 ti - from £79 Wink
Dazbo666
PostPosted: 16:56 - 27 Apr 2012    Post subject: Reply with quote
...or my old Sapphire, and lots of beer money !? Wink
Word of the day : DILLIGAF
Colin Edwards
PostPosted: 17:43 - 27 Apr 2012    Post subject: Reply with quote
2nd time this model was suggested tome today from different people...... I will investigate it..
Any other suggestions?
CE
GrumpyGuts
PostPosted: 20:24 - 27 Apr 2012    Post subject: Reply with quote
I'm going to have to mention the GTX 550ti as before. I would avoid ATi as their drivers are horse shit.
This card is a brilliant budget card as I am using one right now. I bought it when it was a new model so it has gotten cheaper. It plays Blu rays like a dream!
If anything, for under £100, I would get the 550ti. Linky to Ebuyer
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
iMark
PostPosted: 06:46 - 28 Apr 2012    Post subject: Reply with quote
Compare any graphics card to the legendary 8800 GTS 512mb
https://www.hwcompare.com/9815/geforce-8800-gt-512mb-vs-geforce-gtx-550-ti/
GTX 550 Ti is leaps and bounds better, meaning its a bloody awesome graphics card.
Question is, Can your processor handle what ever you plan on running with that graphics card... and does your power supply unit give enough juice to run it? I'm going to assume it needs at least 400w which means you will need at least a 500w PSU with a 6 pin PCI-E power cable on it Smile
K8 GSXR 1000
orac
PostPosted: 14:45 - 28 Apr 2012    Post subject: Reply with quote
you can pick up amd 6850 for sub 100 which according to the site imark posted, has more gut (is more expensive tho)
what res you going to be running, what other hardware are you running.
iMark
PostPosted: 15:56 - 28 Apr 2012    Post subject: Reply with quote
Radeon HD 6850 has slightly lower Core Speed (775mhz vs 900mhz) but overall has better Bandwidth, Texel and Pixel Rates.
"Shader Speed (N/A) MHz"
not sure what that is suggesting but the GTX 550 Ti has 1800mhz ... I'm sure the shader speed for the Radeon HD 6850 can be found elsewhere though.
K8 GSXR 1000
orac
PostPosted: 16:06 - 28 Apr 2012    Post subject: Reply with quote
core speed isnt inportant, its work done. and if i remeber correctly amd dont use a shader core, iirc they run it over stream proccesors
specs here
https://www.amd.com/us/products/desktop/graphics/amd-radeon-hd-6000/hd-6850/pages/amd-radeon-hd-6850-overview.aspx#2
for the 550
https://www.geforce.com/hardware/desktop-gpus/geforce-gtx-550ti/specifications
L-Jam
PostPosted: 22:40 - 01 May 2012    Post subject: Reply with quote
6870 1gb, I have it, if you're going to spend a 1er on a card you can stretch to £120.
Get it, anything less won't be powerful enough for Battlefield 3 at max res + detail (assuming you want to play modern games).
Journalist, student, egotist.
Omega
PostPosted: 02:50 - 02 May 2012    Post subject: Reply with quote
The Radeon 7770 would what I would (and did) go for at about the same price range.
orac
PostPosted: 11:16 - 02 May 2012    Post subject: Reply with quote
problem with that is that is the 6850 is actually more powerful the 7770. the 7770 does however use less power than the 6850
Alpha-9
PostPosted: 11:22 - 02 May 2012    Post subject: Reply with quote
I got a HD4890 that has kept me going for 2 years now, and it's still pretty high-end, 850mhz 1gb GDDR5
But I'm thinking of going to nvidia and was looking at the card that's been posted repeatedly, ATI drivers are indeed shit, and the card is massive and loud Neutral
Fzr-600 1999
orac
PostPosted: 19:25 - 02 May 2012    Post subject: Reply with quote
if you think your gonna get better drivers with nvidia, think again. and all modern high cards are load, how else do they disopate 100+w of heat (well closer to 200w for the 4890).
the 850mhz of the 4890 will do less than a for more energy than a newer card. the 7850 for example uses 60 watts less power but outperforms the 4890 by a sizeable chunk. alos the 550ti is outperformed by the 4890 but uses more than 70w less poewr
infernalrob3r...
PostPosted: 20:26 - 02 May 2012    Post subject: Reply with quote
to be honest i swear to my gtx 460's Smile can get one for way less than a £100. i have 2 in sli and ive never had problems running anything apart from the odd game on stupidly high settings i.e witcher 2 on ubersampling >.> it does look pretty though..
The Wobbly Orange
PostPosted: 00:16 - 09 May 2012    Post subject: Reply with quote
I'm going to echo the sentiments of one of the above posters. Go for the 6870. Is only marginally more but will get you into that territory where you can play all the new games at high to ultra detail provided you are not multiscreening.
People tell me I am lovely. How wrong they are!
Sload
PostPosted: 08:09 - 09 May 2012    Post subject: Reply with quote
Try this site out, you can set different cards too
https://www.anandtech.com/bench/Product/541?vs=540
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
Colin Edwards
PostPosted: 09:38 - 09 May 2012    Post subject: Reply with quote
Helpful...
Thanks
Sload
PostPosted: 11:58 - 09 May 2012    Post subject: Reply with quote
I still have one of those fitted and one still shiny in a box that I never hooked up into Xfire on a C2D OCd to 3.5.
Still runs pretty much everything but on the new stuff you do tend to have to sacrifice detail for FPS, Metro was an example and it wont do Skyrim on full without chugging a bit.
OP never said what he plans to do with it though, as there are a lot of factors that can influence your choice.
The last post was made 13 years, 69 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 102.86 Kb
