It needs to be stiff.! Why will you not go stiff god-dammitt
Nick_Giles
PostPosted: 15:48 - 28 Apr 2012    Post subject: It needs to be stiff.! Why will you not go stiff god-dammitt Reply with quote
Pump and release. pump and release, pump and release. .......... Will it go stiff.? ...... Oh no.!
No matter how hard and fast I pump and release. It stays soft and spongey. Sad
Nick Wink
doggone
PostPosted: 16:03 - 28 Apr 2012    Post subject: Reply with quote
Could you get anything to squirt out?
Nick_Giles
PostPosted: 16:22 - 28 Apr 2012    Post subject: Reply with quote
Yes.
Trying the lever tied back trick for a few hours at the mo.
Would viagra in the fluid reservoir help do you think.? Rolling Eyes
Nick
james1988
PostPosted: 16:29 - 28 Apr 2012    Post subject: Reply with quote
Are you drawing air in through the bleed nipple?
James
Nick_Giles
PostPosted: 16:47 - 28 Apr 2012    Post subject: Reply with quote
James
Fairly sure I ain't as when I pressure the lever and release the bleed nipple each time there are no small bubbles at all in the clear pipe from the nipple.
I hear the banjo bolts are often a fave hiding place for difficult to dislodge bubbles. ?
Nick.
janner_10
PostPosted: 16:50 - 28 Apr 2012    Post subject: Reply with quote
Could be the master cylinder seals also.
Nick_Giles
PostPosted: 16:54 - 28 Apr 2012    Post subject: Reply with quote
This possibility is also starting to occur to me.
I will leave the handle tied back overnight and if its not showing some nice manners in the morning I shall try that course of action.
Nick
PostPosted: 17:50 - 28 Apr 2012    Post subject: Reply with quote
Not so likely.
An easy way to check where the problem is, clamp the brake hose just after the master cylinder. If the lever goes solid, you have air in the calipers. If it's spongey you have air in the top banjo or air/a fault in the master cylinder.
steven_191
Squeeze the pistons back into the calipers and watch the bubbles pour up from the master cylinder. Careful not to over flow the master cylinder though. I did this after a while trying to bleed that way. Took seconds and the lever was amazing
temeluchus
PostPosted: 17:54 - 28 Apr 2012    Post subject: Reply with quote
A syringe is a useful tool to get it hard.
PostPosted: 19:18 - 28 Apr 2012    Post subject: Reply with quote
Did you have the banjo bolts off? In the past, I have managed to mislay a little copper washer on the banjo, and although everything looked fine, it was sucking harder than a smutty in-your-endo.
cb1rocket
PostPosted: 21:59 - 28 Apr 2012    Post subject: Reply with quote
reverse bleed, the traditional method is a pain in the a***
jjdugen
PostPosted: 23:07 - 28 Apr 2012    Post subject: Reply with quote
Hmmm.... Having the same problem at the mo. The caliper bleed through is fine, its the disc / rotor alignment thats the problem.
Work the brake lever whilst watching the rotor nearest the caliper. If you see the disc flexing thats your problem. Something has become distorted on the one I'm dealing with and its not the disc itself. Could be the fork/spinle/wheel alignment that is slightly out. to eliminate all the possibles would be too expensive so, I'll be taking the easy way out and making the errant disc fully floating. A bit jangly but it solves all the problems.
janner_10
PostPosted: 12:49 - 29 Apr 2012    Post subject: Reply with quote
Pete. wrote:
Not so likely.
Excellent tip Pete - wish I had thought of that during my brake problems.
Robby
Dirty Old Man
PostPosted: 13:11 - 29 Apr 2012    Post subject: Reply with quote
You don't need to pull the handle all the way back. In fact, this is a poor way to bleed brakes.
When you drain down the system or install new lines don't think of it trying to get fluid in, think of it as trying to get air out.
The internal core of a brake line is a very small bore pipe. A brake line is contructed of an out rubber or braided mesh cover, then a plastic pipe. Each of these is at least 1mm thick, so the internal bore is 4mm smaller than the external line. So small that air bubbles get in the way of the fluid, and rise up the line very slowly.
When you squeeze the handle, you are forcing in some fluid and compressing the air in the line, shoving the whole lot away from the master cylinder. The correct thing to do is just pull the level back a fraction - about 5% of its total travel. This uncovers the small hole and allows the air bubbles out, without forcing more fluid in. Some fluid will trickle in naturally as the air is displaced.
So, my ten minute method to bleed new line is just to jiggle the lever a few times, wait 20 seconds, jiggle it again, and so on. Watch lots of tiny bubbles coming up into the resevoir. When no more clusters of bubbles are coming up, give the lever a few full stroke, wait, and start jiggling again.
Eventually the lever will go firm, then you can bleed the the calipers in the normal way. Any residual air bubbles will float up the master cylinder when it is standing, and be passed up into the resevoir when you use the brakes normally.
Less is more with brake bleeding. Let the air bubbles rise at their own speed.
Nick_Giles
PostPosted: 14:34 - 29 Apr 2012    Post subject: Reply with quote
Happy days. Sorted.! Very Happy
The leaving the lever tied back overnight with a cable tie seems to have let natural physics take their course.
A big thanks to all those that took the time and effort to contribute to this thread.
Cheers, Nick
thomp1983
PostPosted: 15:35 - 29 Apr 2012    Post subject: Reply with quote
ok stupid question time, when you tie the lever back over night i assume it's with the master cylinder lid off and the bleed nipple closed?
chris
Fizzer Thou
PostPosted: 17:38 - 29 Apr 2012    Post subject: Reply with quote
The bleed nipple does need to be closed and the master cylinder cap does not need to be removed.But if you leave the bike on the side stand with the master cylinder pointing down slightly,this will aid the bubbles to escape through the two holes.
It is a good idea to wrap some PTFE tape around the thread of the bleed nipple.This will help to prevent air getting past the thread when bleeding the caliper or even if you have one on the master cylinder as well.
Always have a 'Plan B'
PostPosted: 19:31 - 29 Apr 2012    Post subject: Reply with quote
Fizzer Thou wrote:
It is a good idea to wrap some PTFE tale around the thread of the bleed nipple.This will help to prevent air getting past the thread when bleeding the caliper or even if you have one on the master cylinder as well.
I just slap some grease or copper slip round it.
hellbound
PostPosted: 15:30 - 30 Apr 2012    Post subject: Reply with quote
I stuck a tube on the brake nipple and sucked fluid through (it was a really long tube!)
then bled them as normal after sucking alot!
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
The last post was made 14 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.56 Sec - Server Load: 4.22 - MySQL Queries: 13 - Page Size: 109.87 Kb
