| flumpy7 |
 flumpy7 Could Be A Chat Bot
| andym |
 andym World Chat Champion
| janner_10 |
 janner_10 World Chat Champion
| HD |
 HD World Chat Champion
| flumpy7 |
| HD |
| flumpy7 |
| HD |
 Posted: 23:05 - 20 Apr 2012 Post subject: |
You 100% it doesn't split as the rear on my Derbi was a tiny 2-pot and that did? And yeah clamping it down with something usually works, like mole grips again, best tool for doing brakes haha! And its not that hard to pull them out sometimes, other times like this you've got no hope  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| janner_10 |
| Budgetboy |
 Budgetboy Scooby Slapper
 Posted: 23:18 - 20 Apr 2012 Post subject: |
As others have said connect the brakes up again and use fluid.. But heres a little tip..
Get a pick and pull out the old dust seal if you can before you connect the brakes back up.
if you are rebuilding them you wont mind ruining the seal,just go steady.
there will be less resistance on the piston then.  ____________________ www.Mailorderrepairs.co.uk We service your Carburetor's, Calipers & Suspension for less Also Bike repairs undertaken. |
| steven_191 |
 steven_191 Nearly there...
 Posted: 09:59 - 21 Apr 2012 Post subject: |
If you do use grips to pull it then be careful and make sure you don't leave any burrs. This may fuck up the new seals.
There are pullers but not sure how effective it would be considering how stuck it is.
Also you could try attaching it to a bigger master cylinder to get more power through the line ie the front master cylinder.  |
| Vincent |
 Vincent Banned
 Posted: 10:43 - 21 Apr 2012 Post subject: |
The problem is that you're looking up how to do this after and not before attempting the job. If you had looked before, you'd have seen that you shouldn't pop out the loosest piston until the other one has started to move. So you apply pressure, then when the first piston starts to move, stick a block of wood or something on top of the piston to stop it moving any further. Apply pressure again and the other one will pop out.
You need to reinstall the removed piston, bleed the system and try again. Make sure the seal is good on the re-installed piston.
You could see how much a new piston is, they vary in price depending on how they're made. If it's cheap, pull yours out with a pair of mole-grips and replace with a new one. I have a front wheel off one of these in the lock up. Is the caliper inside the disc cowl?
Not much help I know but you might remember to look fist next time  ____________________ Space Is Deep |
| andym |
| flumpy7 |
| andym |
| flumpy7 |
| bikenut |
 bikenut World Chat Champion
 Posted: 10:59 - 23 Apr 2012 Post subject: stuck piston |
hi dude,
reassemble so u can use hydraulic pressure, place caliper in hot water and pump away..........or use heat gun and pump away........some pics and results would be good. |
| bagger |
 bagger Nitrous Nuisance
| Vincent |
 Vincent Banned
| Kickstart |
 Kickstart The Oracle
 Posted: 09:58 - 28 Apr 2012 Post subject: |
As others have said, reassemble, bleed and pump the pistons out, blocking them so they both come out together.
If the bleed nipple is not sealing then you have a bigger problem, as that is only an issue if the bleed nipple is tightened up. If it is leaking when tightened up then the caliper needs some work (ie, possibly drill out the bleed nipple and cut a thread for the next size up, but take care that it will still seal) or better being replaced.
| Vincent wrote: |
I think that's only any use if the pistons have inserts. |
Think it relies on having hollow pistons (ie, no inserts, or insert removed - not the really annoying ones fitted to early ZZR600s for example that look like they are filled up with a mix of powdered wood and resin). I presume he means a rawl nut (the rubber mounted nuts which squeeze out as you tighten them, often used in small sizes on fairings and commonly known as well nuts).
| Stonefly |
 Stonefly Scooby Slapper
 Posted: 19:03 - 28 Apr 2012 Post subject: |
| Kickstart wrote: |
Think it relies on having hollow pistons (ie, no inserts, or insert removed - not the really annoying ones fitted to early ZZR600s for example that look like they are filled up with a mix of powdered wood and resin). |
My 2000 E7 ZZR600 has those insert disc things in the pistons. 3 out of the 8 are knackered now from extracting the pistons during a caliper refurb. Can i just put the pistons back without those things? or do i need to get new ones? Kawasaki do not supply them individually - they only come as part of a new piston, which i dont need. I was told to just bin them and put copper grease on the back of the pads - is this correct? has anyone done this with ZZR calipers?
cheers
(apologies to the OP for hijacking the thread) ____________________ Current......Kawasaki ZZR1200 C2H and Kawasaki ZZR600 E7
Previous....Yamaha FS1E, Honda SS50, Suzuki AP50, BSA Bantam D14, Honda CD175, Honda CB250N, Kawasaki Z250A3, Yamaha RD250E, Kawasaki Z400, Kawasaki Z500, Kawasaki GPz550, Honda NTV600, Kawasaki GT750, Kawasaki Z1000R, Kawasaki GPX250 |
| Kickstart |
 Posted: 21:22 - 29 Apr 2012 Post subject: |
You have just made me think. Some ZZR600s have plastic stuffers that can be easily removed while others have the odd ones moulded into the pistons.
As to removing them, not sure. You probably can get away with it. However I suspect the main purpose of them is to insulate the calipers (and the fluid) from much of the heat generated in the pads. Remove them and the fluid will probably get a bit hotter. Also they are slightly proud of the pistons, so without them the pistons will need to come out slightly further for the pads to contact with the disks. Doubt by a critical amount but just something to be aware of.
The last post was made 14 years, 180 days ago. Instead of replying here, would creating a new thread be more useful? |
