| ClydeGhost |
 ClydeGhost Nitrous Nuisance
 Posted: 14:09 - 30 Apr 2012 Post subject: I dont understand countersteering. |
What? Push to the left turn right, push right turn left. EH? I was just sent this link https://www.youtube.com/watch?v=B8IdTq3_3WI&feature=relmfu and was unsure about counter steering. I don't understand this and I fear that if I try it I may just end up having another accident. Can someone explain further rather than 'push left you turn right if you're going more that 10mph'
Or is it something i'll pick up eventually? ____________________
Honda CBF125 : Suzuki GS500 |
| sheriffjonny |
 sheriffjonny Nitrous Nuisance
 Posted: 14:33 - 30 Apr 2012 Post subject: |
If you really think about what you do already, you will probably find you are doing it anway. The idea behind it sounds weird. If you think about it, when you go round a corner, you lean into it, you don't actually turn the handlebars into the turn.
Say you were going around a left bend, you lean into the turn, now if you were to turn your handlebars to the left, you would actually be putting the wheel sideways against the direction of force, if you turn the wheel slightly to the right you will negate this effect. Just remember that you aren't making any big dramatic turns here, it really is a slight movement. Als it comes down to the speed you are going, at lower speed you may actually turn te handlebars as you don't have to power to keep you up against gravity if you lean into it ____________________ Current bike........'09 Honda CBF 125, seeking new big bike............New bike found '01 Honda VFR 800 |
| soforene |
 soforene Nearly there...
| Alpha-9 |
 Alpha-9 Super Spammer
| J.M. |
 J.M. World Chat Champion
 Posted: 14:47 - 30 Apr 2012 Post subject: |
If you're turning a corner you are counter-steering. You're already doing it on your everyday riding.
Also it's a common miss-belief that leaning off of the bike causes you to turn a corner sharply. The image below shows that even fully leaning off of the bike, without counter-steering, you're just going to go in a straight line:
https://moto-technique.co.uk/images/counterSteer.jpg
Basically counter-steering is what causes you to turn. When you lean the bike over, the bike naturally does it. Understanding what it is merely enables you to consciously do it.
The image below shows counter-steering in action. Basically, when the wheel is turning to the right (push the left bar forwards), the bike actively tips to the left:
https://image.sportrider.com/f/8858452/146_0110_zoom+ducati+front_side_view.jpg
Edit: Images fixed. The college filtering policy is such a pain in the arse. Tor, I love you. ____________________ 2004 R1 & 2018 XSR900
| ClydeGhost |
| Alpha-9 |
 Posted: 14:56 - 30 Apr 2012 Post subject: |
Those images failed entirely J.M, not even the direct link works
| ClydeGhost wrote: | That's cleared it up a little, sorta, kinda, maybe, should've, eh. There I was thinking that I've been doing it wrong all this time. So, like, basically, as you're about to turn you slightly push the handle bar to the left (if taking a right turn) but then bringing it back to the right? right? by leaning? What I do is move a little to the left then turn the handlebars back to the right. I'm very shaky round corners anyway and this is how i've always done it. |
Don't think about it, stop over thinking every aspect of your riding.
You really don't need to consciously think about countersteering, it can be useful to consciously do it while turning if you need to make it sharper, but mostly you'll just confuse yourself.
Just get a feel for it, countersteering is natural, it's what keeps the bike upright and its what makes you so wobbly at low speeds, you automatically correct the wheel by tiny amounts in order to stay balanced, with a bicycle you do it constantly but a motorbike generally does little corrections by itself, that's why it's more important to be relaxed and loose than it is to worry about what you're doing constantly. That's how I feel it anyway...
Get some practice on your own out of traffics way and get a feel for countersteering consciously to see what happens  ____________________ Fzr-600 1999 |
| tlartist |
 tlartist Two Stroke Sniffer
 Posted: 14:57 - 30 Apr 2012 Post subject: |
Maybe think of it like this. Push with your left hand if you want to turn left. Push with your right hand if you want to turn right. Try it at speed to see what happens. Ride toward a point on the road and press somewhat hard with left hand to go left. Might also help to turn your head to the left as well. ____________________ Please see my motorcycle tire review sites at https://www.allmotorcycletirereviews.com and https://www.mototirereviews.com. |
| Gazza M |
 Gazza M Crazy Courier
 Posted: 15:04 - 30 Apr 2012 Post subject: |
when you want to turn, you basically need to shift the centre of gravity of you and the bike out of 'line' with the wheels, so the bike counteracts this by turning.
all that countersteering does is very slightly steer the bike to the outside of the turn to initiate the lean - then the turn will come.
so - to turn right - push on slightly on the right handlebar. bike will lean to the right. very little input is needed really.
if you feel a bit shaky doing it, try on a pushbike to get a feel for countersteering - this makes it a lot easier to see what is going on.
HTH  ____________________ Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike |
| Teflon-Mike |
Youre already 'Counter-Steering'. You just dont do it conciousely.
The principle, and its over proliferated explanation is gyroscopic progression.
This is the pehnomonon of a rotating body, when subject to a deflecting force to react with an opposing force, but offset by 90 degrees.
Example is to get a push-bike wheel, hold the spindle in each hand then get some one it give it a good spin.
Try and turn it to the left, and it will react by trying to tilt top left.
Have a play.
On a motorbike. works thus; if you put PRESSURE on left bar, G-P makes bike try and LEAN left, hence steer left, propagating steering.
And you DO THAT NATURALLY of you would have CRASHED long before now! Its how bikes steer!
What people are talking about is CONCIOUSE Counter-Steering, which is to DELIBERATELY and CONCIOUSELY load the bars to MAKE it do that MORE, and hence lean and steer faster.
Rather than how you do it sub-conciousely, which is to use a little 'ahead lean' tilting your upper body from the centre line, and applying a very SLIGHT pressure to the bar to make it tilt and start turning.
Once you have got the idea, you can use the effect to speed up tuirning, or as I do on heavier bikes, make them move more readily with less body movement or effort. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Howling TerrorOutOfOffice |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| Alpha-9 |
 Posted: 15:24 - 30 Apr 2012 Post subject: |
Seriously, don't think too hard about it.
Leave her alone and let her build her confidence up in general before worrying about advanced riding techniques. The poor girls bombarded with overthinking and seemingly scared of riding now
| ClydeGhost |
| snikks |
 snikks Spanner Monkey
 Posted: 16:42 - 30 Apr 2012 Post subject: |
I found this video : https://www.youtube.com/watch?v=EFm3honeTQo helped me to get my head around the idea. Quite a good explanation.
That said, the best way to learn it is to just go out and (very carefully) try it. You'll soon get a feel for it. ____________________ - CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:13 - 30 Apr 2012 Post subject: |
Do it consciously, have the "Oh, so that's how it works!" moment. Then forget about it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Sako |
 Sako World Chat Champion
 Posted: 17:14 - 30 Apr 2012 Post subject: |
have to agree with the people who mentioned going out and trying it - its the only way you will get your head around the concept - best of luck!  |
| TheSmiler |
 TheSmiler World Chat Champion
| ClydeGhost |
 Posted: 20:19 - 30 Apr 2012 Post subject: |
YAAAAAAAAAAAAY. I went out on my very first proper ride to work today, was very shaky still at pulling away/turning/cornering but I thought 'Fuck it' and went on my way. I haven't had a proper ride because of the weather but now that it was nice and clear I took advantage. IT WAS GREAT. Ugh, it felt awesome, I don't know why I was so terrified, but I guess that's always the case. I also tried the counter steering and I get it now, I'm not going round a corner at high speeds but I get it. CHEERS BUNCHES GUYS  ____________________
| Flatbadger |
 Flatbadger World Chat Champion
| Jynister |
 Jynister Nitrous Nuisance
| John933 |
 John933 Crazy Courier
 Posted: 23:06 - 30 Apr 2012 Post subject: |
I had the same question running round in my head for some time. Just could not get my head round it. Let me take you on a journey and may be you will see. Go back when you where very young and rode your push bike round with no hand's. Remember them day's? We all did it. Then the next thing you found was that you could go round corner's with no hand's a new skill. That one piece of information should tell you that you can steer a bike with no in put to the handle bar's. So what's happening?. You move your weight the bike tip's to one side. The bike turn's. You get up right again and the bike goes straight. Simple. The same on Power two Wheel's.
The turn left to go right, or the other way round is. Just as simple. In this case if you are travelling in a straight line. And do a quick short movement to one side. The change in direction will throw all the weight to the other side. Now if you quickly lean with the weight. So you want to go left. Bang in a quick nudge to the right. The bike is falling to the left. You lean with it to the left. Changing the steering to go left, And you are down low getting round at a good rate of knot's. It just drop's the bike in quicker. All in all you don't need that kind of quick movement on the road. Just leaning in the right direction will get you there. Once you do it and worked out what's happening. As I did. Hell I thought I don't need to turn that quick.
That kind of steering is for the race track, not the hight-way,
Hope that help's
John933 ____________________ My trip |
| pendulum |
 pendulum Traffic Copper
| Ayrton |
 Ayrton World Chat Champion
| bikertomm |
 bikertomm World Chat Champion
 Posted: 01:33 - 01 May 2012 Post subject: |
Learnt this within the first couple of days of riding, I knew it would work, but when I came up to a smooth left hander and pushed forward gently on the left grip -
Mind = blown.
Epic, I find it helps balance the bike, leans it in nicely and ever since I have actively countersteered
Doesn't feel like you are wrestling with the bike at all which is almost what it felt like on my first day. ( I was doing it wrong )
 ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
The last post was made 14 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
