| Artur |
 Artur Nitrous Nuisance
 Posted: 21:28 - 29 Apr 2012 Post subject: Talk to me about batteries |
Hi all,
so my Hornet 04 is having issues starting up lately
The starter engine turns over but very weakly, and I had to push start it a few times.
I think is the battery as I have recharged it and a couple of days later it doesn't start again, so it isn't holding the charge. I don't have an alarm or heated grips or anything connected to the battery.
Now, I need a battery and it's the first time I am buying one.
What options do I have, which type is better for a bike that is only riden occasionally, as in, good weather/days off, and mainly short distances.
thanks  ____________________ - Honda Hornet 600cc '04 |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:30 - 29 Apr 2012 Post subject: |
Buy a decent quality battery of the same spec and invest in a trickle charger to keep it in good condition. ____________________ My Flickr |
| Artur |
| andys675 |
 andys675 World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 21:57 - 29 Apr 2012 Post subject: |
Motobatt  |
| Fizzer Thou |
 Posted: 23:15 - 29 Apr 2012 Post subject: |
I found that these people gave me good service
https://www.tayna.co.uk/Honda-CB-600-Hornet-Motorbike-Motorcycle-Battery-R2193.html
But if you can check that the battery is being charged properly first then you will not be wasting your time by buying a new battery when it might be something else.
If you can get a hold of a multimeter,check the voltage across the battery with the engine off.If it is about 12.5vdc that is normal.When you switch on the ignition does it drop to below 11vdc?When you press the electric start button does the voltage drop to way below 12vdc?
Once the engine is started does the battery voltage rise to around 13.5vdc?If you rev the engine does the battery voltage rise towards 14vdc? ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Artur |
 Posted: 00:42 - 30 Apr 2012 Post subject: |
| Fizzer Thou wrote: | I found that these people gave me good service
Once the engine is started does the battery voltage rise to around 13.5vdc?If you rev the engine does the battery voltage rise towards 14vdc? |
Will check that tomorrow. Thanks  ____________________ - Honda Hornet 600cc '04 |
| keggyhander |
 keggyhander World Chat Champion
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| hellbound |
 hellbound World Chat Champion
| Artur |
 Posted: 17:16 - 30 Apr 2012 Post subject: |
Right, did some checks with a multimeter.
Engine off: 12.15v
Ignition on: 10.50v
Pressing the starter: droped way down to about 5v/6v (engine did not start).
Took the battery off, it's on charge with a Oxford charger/optimizer. the charger has 4 indicators which tells you what is the condition of the battery: RED: not recoverable. Orange: very low, might recover it. Yellow: low charge, will recharge and optimize. Green: battery healthy.
Mine was in the yellow. After 2h on charge is now showing green so it must be on a trickle charge I assume.
For how long should I leave the battery connected to the charger now? ____________________ - Honda Hornet 600cc '04 |
| Walloper |
 Walloper Super Spammer
| Artur |
| Walloper |
The last post was made 14 years, 164 days ago. Instead of replying here, would creating a new thread be more useful? |
